HELP SC400 Starting issue
Old Mar 4, 2014 | 05:33 PM
Hobanero's Avatar
Hobanero
Default HELP SC400 Starting issue
I have a 92 SC400 that is turning over but not starting only here and there. I had it towed over the weekend to have the dealership tell me it was a bad battery contact and then it failed to start again, another shop ran diagnostics and says it is a bad starter motor? I looked up the cost of replacing and am praying it may be something else. The engine turns over and the belts turn but it just won't fire up. I removed the battery cables and put them back on and the car fired up but failed to start again later in the day. I keep getting mixed information and have already taken the vehicle to 2 shops, haven't heard the infamous starter click either...Any suggestions?
Old Mar 6, 2014 | 12:58 PM
Shrugy's Avatar
Shrugy
Look into getting your ECU rebuilt.
I paid 150$ and this solved my starting issue. I also have a 92 SC400 and I had to get mine towed as well.
I also bought new battery terminals.
If you flip the key to the ON position, this is the position right before you initiate the starter, does a Check Engine Light illuminate on the dashboard?
If not, this is a result of your ECU having leaking capacitors and causing your vehicle not to start.
I had all of your symptoms you have stated. I also replaced my starter switch.
Old Mar 6, 2014 | 06:18 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Or it's a result of a burnt out bulb in the cluster...
Old Mar 7, 2014 | 08:01 PM
Shrugy's Avatar
Shrugy
This is a likely possibility ^^
Bott63
Maintenance
21
Dec 7, 2015 03:58 PM
miii429
Nov 15, 2014 01:34 PM
zronron
Sep 6, 2014 04:21 PM
jpvarghese
Aug 21, 2012 12:55 PM
