97 rear defroster help!
I just had my son's rear window replaced with a used one from a sc400. The window appears fine with no breaks in in the defroster.
The old window had 2 connections on the passenger side and 1 on the driver towards the top.
I have 13.2 volts from the hot to the negative on the passenger side.
The window defroster seems to split the window in 1/2. It goes from the positive across on the bottom 1/2 to the driver side then back to the passenger side where the negative terminal.
I used my amp probe and it's drawing nothing.
I'm drawing a blank with this as it "should work" cause I can't find any breaks in the defroster.
Any help with this would greatly be appreciated.
Chris
Chris
six30two
Dec 27, 2008 08:17 PM
