KA24DE Trans on SC400?
^^ custom driveshaft. KA trans coupler on the transmission side and either an SC front shaft connection to the SC carrier bearing or just a big, long one piece driveshaft from the KA transmission to the SC rear diff. Same as pretty much any mixed-manufacturer swap.
I get my w58's at the junkyard. I've had 3 because the first lost a main seal, the second was whining (it was my buddy's old drag trans) and blew the gears. Other than that the'yre plenty strong. My friend has a 1jz cressida with 500whp and it's fine, and mine has 300 whp and it's fine (replaced all the seals). I don't see any reason for putting a truck trans in place where another truck (w-series) trans can go with ease. Plus all those s13/14 guys buy them up at the junk yard. The W-series came in most everything (except the turbo truck and the turbo supra) so they're pretty east to find at the junkyard.
I can agree, i don't know what junk yards are like out there, i assume full of GM/ Ford products. IDK if they even have a pick a part out there. But if they do, here's a helpful W-series link
http://en.wikipedia.org/wiki/Toyota_W_transmission
and i think all toyota except the R/V series have the same output shaft size.
So no more info on this build I have a 99 sc400 1uz vvti
I'm trying to so this swap and thing well help I know the clutch fly wheel clutch paddle costum drive shaft etc is that it ? And engine removal ? I hear some ppl losen then engind mounts and tilt the engine but that's for a w58. Is it different with the ka trans ?
There is two specific threads in the build section that cover this swap. Afaik, the Ka swap is easier than any if the others (if speed sensor isn't important to you or DDBox it). I'm on my cell so I can't reference them but they are bookmarked on my PC. Basically all you need is the tranny, adapter plate, hydraulics (pedals, master, line), clutch/flywheel (clutch will be KA and flywheel will be Tacoma). You can even use the spline adapter to get the 240 shaft to fit without cutting. When I priced it out I came to $1k total (my price with contacts).
Good luck
Good luck
Please give any more details you have about this swap.
Because if you can dramatically lower the cost of a manual swap into a SC400, I'm all in. I would do this swap if it was a little bit more affordable on any given day!
Please do not let this slip away! I am very interested.
https://www.clublexus.com/forums/sho...238&styleid=13
Adapter plate (for shaft to dif) is $179 at a website (can't post outside links) called te driveshaftshop iirc
Adapter plate for bell housing (with shaft extension for clutch) is $600 - $1200 depending on which if te three sites you pick (once again outside link) which I found on Soarer central.
Pedals sc300, supra, or the stock KA24 pedal can be made to work (it's on CL how to make any of these work)
Clutch hydrolics can be had under $100 if you go with wildwood
Shifter, might get a free one but a real nice one can be had for under $200
Tranny mount will be the Sc one modified to fit the Nissan mount
And last lye is the trim piece. I seen a used one go for $40 in the user classified but can be found brand new under $200
Hope that helps. If I could post links it would be easier to show you. This is my plan, I already got the master and tyranny. My 240 shaft was bent so....... I'll prolly cut my Sc one and fit the Nissan yoke on there for about $150
Here is another thread using te Nissan 6speed. The swap is the same just different tranny (dimensions are roughly the same too)
https://www.clublexus.com/forums/showthread.php?t=644590&styleid=13
^^ This is what I've been reading. The Z32-TT 5-speed is supposedly in the class of the Toyota R154. Conversely I've also read that the R154 is a superior transmission to the RWD 5-speed manual boxes that came in 1989-2002 2.5L GTS-T Skylines. Is the Z32-TT box the same as that one? I also once read about an whole 6-speed transmission Greddy or some other company sold for S14/S15 Silvias to replace their fragile factory 6-speeds.
Anyway, it sounds like the KA24DE 5-speed can take a fair beating to a point. I'm curious as to how it stacks up against the Toyota W58.
joeazy187
Apr 10, 2009 05:13 PM
nofish
GS - 1st Gen (1993-1997)
Nov 30, 2007 06:35 PM
