Shift solenoid code help
Old Jan 8, 2013 | 02:05 PM
TripHopBoy's Avatar
TripHopBoy
Default Shift solenoid code help
Hey guys I got my 1996 sc300 a couple years ago.. when I bought it the guy had covered up the check engine light with black tape.... couldnt even see it.... so that year I had a major tuneup done with the timing belt ect.... and the code that was present was "p0773" transmission shift solenoid...
I had the mechanic replace the solenoid,fluid and filter at the time. after clearing the code it past inspection and ran for most of 2012 with the light off.
of course now that my inspection is due again the light comes back on literally a week before i was going to get it inspected. I cant really afford to go have the same procedure done again this year....I spent all my money just getting the registration and a damn red light camera ticket payed off.... is there anything else I can do? I suppose to prevent this in the future the transmission would have to be rebuilt? thanks.
Old Jan 8, 2013 | 02:12 PM
2jzcoupe's Avatar
2jzcoupe
Have you had the engine light checked? If so is it the same code?
Old Jan 8, 2013 | 02:15 PM
TripHopBoy's Avatar
TripHopBoy
no I havnt had it scanned.... cant afford it but I can almost promise it is the same code.... this happens to camery,s and es300,s too. its a common toyota code....the light came on twice throughout the year and both times it went back off after a few days. but no this time.....
Old Jan 8, 2013 | 02:19 PM
2jzcoupe's Avatar
2jzcoupe
You cant really say thats it for fact with out it scanned if you go to autozone they will scan the code for free.
Old Jan 8, 2013 | 02:20 PM
2jzcoupe's Avatar
2jzcoupe
You could also unhook your battery for 5 min and it will clear the light and then drive it 30 miles so it can check all monitors and if the light did not come back on go to emissions.
Old Jan 8, 2013 | 02:24 PM
TripHopBoy's Avatar
TripHopBoy
thanks i willl run to autozone...
Old Jan 8, 2013 | 02:52 PM
TripHopBoy's Avatar
TripHopBoy
good call on that man.... the scan came back p0401....EGR valve...any trick to clean the egr or just have to replace?
Old Jan 8, 2013 | 02:57 PM
2jzcoupe's Avatar
2jzcoupe
p0401 is that the insufficient flow code?
Old Jan 8, 2013 | 03:00 PM
TripHopBoy's Avatar
TripHopBoy
yes it is.
Old Jan 8, 2013 | 03:06 PM
TripHopBoy's Avatar
TripHopBoy
found this vid that helps a little.
Old Jan 8, 2013 | 03:10 PM
2jzcoupe's Avatar
2jzcoupe
Ok there are a few checks you need to do before saying its the egr valve.
1. find a hand vacuum pump and with the car running apply vacuum to the EGR valve the engine should start to run pretty rough or it die.
If it does not do anything then you may have a clogged egr port unbolt the egr valve and make sure the port is clear of any carbon and then check the egr tube that goes to the exhaust for carbon.
now if it does start to run rough you know that your EGR valve is good and has no carbon build up so you have to move on from there.
2. Now you can check the egr valve switching valve this is a solenoid that turns the egr valve on.
You need to unplug it and put power and ground to it and see if it clicks if not that is more than likely you problem.
if that seams to test good then you need to look at the egr modulator this is like a little filter and gets clogger and wont allow and vacuum flow to the egr.
Here is a diag. of the egr system its missing the switching valve though.
http://www.dealerdirectparts.com/v/v...os/8904170.gif
Old Jan 8, 2013 | 03:11 PM
2jzcoupe's Avatar
2jzcoupe
Ya that is for a for I would go through those checks I listed and you will fix it or at-least find your problem
Old Jan 8, 2013 | 03:18 PM
TripHopBoy's Avatar
TripHopBoy
Sweet bro thanks for that info. I think this is a good sign its time to do the plugs, wires,cap,rotor, clean the throttle body and replace the o2 sensor.... anything else I might need to do for the top end tuneup?
Old Jan 8, 2013 | 03:22 PM
2jzcoupe's Avatar
2jzcoupe
seems pretty complete I would fix that egr code before anything else so you know its fixed and not anything you changed.
Old Jan 8, 2013 | 03:24 PM
TripHopBoy's Avatar
TripHopBoy
Yeah I have to get that code handled asap for inspection. good stuff I owe you one man.
Smileme
Nov 15, 2018 07:17 AM
missvorn
Feb 26, 2015 06:48 AM
imjohnphan
Apr 29, 2011 03:06 PM
youngwatts
RX - 1st Gen (1999-2003)
Sep 22, 2006 07:34 PM
