Front lower control arm bushing question
Old Oct 1, 2012 | 07:22 PM
2jznosht's Avatar
2jznosht
Cool Front lower control arm bushing question
So...the stupid metal shell that the trashed bushings were in are also trashed. Because of this the bushings that came in the kit won't work. My question is which bushings don't need the shell to work and where can I find them?
Ps will these work without the shell? http://http://www.ebay.com/itm/IMC-3...c85151&vxp=mtr
Old Oct 1, 2012 | 07:32 PM
OG Dada's Avatar
OG Dada
How did it get trashed? You mean, you made a mistake and trashed it, right? No other way but to buy another CA, bro. Just get a used CA with good ball joints if you don't want to spend too much.
Old Oct 1, 2012 | 08:40 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If I read this correctly, the metal collar that needs to be cutout is also trashed? How did this happen? Regardless, if I read this right, you need to remove the inner liner anyway. Just make a slit in it with a saws all blade or something similar. The bushings will then go in with ease after that. I used some steel wool and a wire wheel in a drill to clean the inside of the control arm after the bushing collar was cut out. I used a huge pair of channel locks and went in with ease.
Forgive me folks if I read this wrong... Just trying to help!
Post a picture of what you are talking about. I tried the link like three times and a no go.
Old Oct 1, 2012 | 10:17 PM
2jznosht's Avatar
2jznosht
what I mean is the metal things the bushing fits into. I found some that dont require the stupid sleeve though.
bradland
58
Jan 4, 2020 08:42 AM
grindin8o8
Jan 30, 2019 05:46 AM
gsxr79
Suspension and Brakes
Nov 30, 2009 06:48 PM
KingNasGS4
Sep 21, 2009 04:15 PM
EpixINC
Mar 13, 2008 10:20 PM
