Problem with power windows sc300!
Old Apr 19, 2012 | 12:15 AM
Tommy2JZ's Avatar
Tommy2JZ
Default Problem with power windows sc300!
ok so my next on the to-do list of fixing up my car are the power windows. they dont work. previous owner said it was the switches. i wanted to hear what you guys thought it was. neither window switch works on passenger door OR driver door. only thing that works is the driver side "lock doors" switch. doesnt unlock it just locks. lol.
this is not my interior lol i wish mine looked like this. anywho. as labeled the only thing that works on either door (excluding the door handles and locks) is this one unlock door switch. when i press the driver side lower window button i can here the motor try but its really weak. any ideas? should i just replace both switch panels?
also. those seat buttons dont work either. any ideas on that? lol
Old May 16, 2012 | 12:50 PM
GamblerZ's Avatar
GamblerZ
Has the battery been disconnected recently?
Old May 16, 2012 | 12:55 PM
Tommy2JZ's Avatar
Tommy2JZ
Yea I disconnec it everytime I'm going to work on it, I heard the motors, regulators and switches. Always go out in these cars
Old May 16, 2012 | 01:03 PM
GamblerZ's Avatar
GamblerZ
It is my understanding that the switches lose their memory and require resetting. My apologies for not knowing more, but I am VERY new to all this and I have just been reading through the site. I am confident a simple search would yield results for the how-to for resetting the window switches.
Old May 16, 2012 | 04:42 PM
WadeLovell's Avatar
WadeLovell
First check the fuses.
Since the switche are not working on either side, it is much less likely to be wiring harness as it goes into the door.
At least since the windows are not falling down the problem is not the regulators where the cables tend to break ,.
Old May 17, 2012 | 02:35 AM
Tommy2JZ's Avatar
Tommy2JZ
what i noticed is the switches have no power. the cables do though. idk whats wrong with them. =/
where would the fuses be...? lol sorry SC noob lol
Old May 28, 2012 | 07:42 AM
rhetty95sc's Avatar
rhetty95sc
I am having same problem but my ds window switch makes a whining noise anytime I push up/dn on the switch, Windows work maybe 10% of the time I try them?? Thought it may be an intermittent conn in the door but there must be pwr present because of the whining when activated? maybe a gnd?? wtf????
Old May 28, 2012 | 08:41 AM
Luxor's Avatar
Luxor
There is most likely a broken wire in the door jamb and it is most likely the big white wire with black stripe. Same thing happened to me, the button would make a buzzing noise.
Old May 28, 2012 | 10:09 AM
g4ebguy90's Avatar
g4ebguy90
Yea My switch didn't work either, I then slit the rubber hose from the door to the car, and found 2 broken wires. I repaired them and now everything works. The weird thing is, that the one wire, when it was disconnected, my switch wouldn't work the driver or passenger windows. Then fixed it worked both.
Old Jun 1, 2012 | 04:37 PM
rhetty95sc's Avatar
rhetty95sc
That is exactly what I found today...THANK YOU!
Old Jun 1, 2012 | 05:33 PM
SC400-PHAE's Avatar
SC400-PHAE
had the same problem big thick light blue wire was broken put it back together an now it works like a champ
Old Jun 1, 2012 | 05:46 PM
Luxor's Avatar
Luxor
Awesome, I am glad it helped out
Old Jun 8, 2012 | 03:45 AM
Tommy2JZ's Avatar
Tommy2JZ
i love you man.. this fixed it lol
Old Jan 20, 2019 | 08:55 AM
GHOSTDOG's Avatar
GHOSTDOG
Default Solved Thanks 😊
Problem solved 😊Big White Wire with the Black stripe was Broken,Now my Windows can roll down again😊
sparks11
RX - 1st Gen (1999-2003)
Apr 29, 2014 07:31 PM
pink
GX - 1st Gen (2003-2009)
Aug 11, 2009 07:50 PM
ssssss
Jul 1, 2008 02:55 PM
Hai_Nguyen
Maintenance
Mar 10, 2006 01:28 PM
yov6cam
Mar 16, 2003 10:15 PM
