Hypereutectic pistons?
Old Apr 14, 2012 | 11:53 PM
g4ebguy90's Avatar
g4ebguy90
Default Hypereutectic pistons?
So I just read a interesting article on the 1UZ.
The pistons are hypereutectic, and I assume forged? Cast ???
Either way, it says that these type of pistons do not take as much damage from detonation as a regular piston would, a aluminum piston lets say in a iron block.
So I am just trying to figure out why toyota never boosted these engines from factory. The v8's have about all they need to be a good performer.
Is there any short comings of the UZ that anyone knows of? Personally I like aluminum engines as you don't go to bore them and match the pistons, you just slap in a new liner and plop them in and off you go...
Old Apr 15, 2012 | 04:19 PM
stockhatch's Avatar
stockhatch
Hypereutectic are high silicon content cast. They are great pistons in that they are stable and do not expand once heated like a forged piston will. They CAN work in boosted applications, and are generally considered better than cast, but weaker than forged.
If designed for boost, hyper pistons can work really well, as the stock gte pistons have proven. If NOT designed for boost, results can be hit or miss. A lot depends on the top ring land depth, compression ratio, ring gap, etc.
Bottom line is that the material the piston is made of is not nearly the most important factor when it comes to detetmining whether an engine will work well with forced induction.
You can boost pretty much anything. People have put turbos on lawnmowers. The question is, how long will the engine last?
Old Apr 15, 2012 | 04:38 PM
spoolxexo's Avatar
spoolxexo
Hyperutectic cast pistons are generally more brittle than forged counterpart, when they do break pieces fly off.
When you detonate a Forged piston, it looks like Terminator 2.
I agree you can make a really nasty 1UZ just by installing Forged pistons with a CR of around 8.5:1, so do it!
MileHIFcar
IS F (2008-2014)
16
Sep 28, 2017 11:52 AM
Mr Jokster
Oct 1, 2016 09:58 AM
phamxOC
Mar 20, 2012 07:35 PM
scmissle
Nov 30, 2011 06:39 PM
puff
Performance
Aug 19, 2011 10:02 AM
