Annoying brakes
Old Jan 30, 2012 | 01:35 PM
ScBouncE's Avatar
ScBouncE
Default Annoying brakes
I recently installed the LS400 brakes a couple months ago but my front drivers side makes a rattling noise over bumps.
I noticed this doesn't occur when I press the brakes over and go over bumps so I assumed it was the brake pads that were loose. I got it checked out and the mechanic told me it was missing some sort of springs???
He told me I should look for some sort of spring kit.
Is there even such thing?? I been dealing with this for more than 4 months. Any help is appreciated.
-BouncE
Old Jan 30, 2012 | 02:32 PM
AnonymousG's Avatar
AnonymousG
I'm not too familiar with e LS400 brakes, but isnt there a spring clip that holds the pads in place?
Might want to look in replacing those, since they should be pretty cheap. or atleast bend the ones you have to put more pressure on the pads.
Old Jan 30, 2012 | 07:32 PM
CrazySC300's Avatar
CrazySC300
Your mechanic must be talking about "Anti-rattle Shims" and "Anti-rattle Springs".
Old Jan 31, 2012 | 01:48 AM
ScBouncE's Avatar
ScBouncE
Anti rattle shims sounds good. Is there a part number? Or for the springs?
Old Jan 31, 2012 | 05:14 PM
afro88's Avatar
afro88
You can buy anti rattle springs from Rockauto.com. If you buy Akebono pads they come with a material on the back of them that don't require the use of the anti rattle shims.
Old Jan 31, 2012 | 09:32 PM
CrazySC300's Avatar
CrazySC300
I can definitely help you out with the part numbers, But I need to know what year LS did these brakes come out of?
Old Feb 1, 2012 | 01:38 AM
ScBouncE's Avatar
ScBouncE
Their from a 98'. Appreciate that !
Old Feb 1, 2012 | 01:46 AM
CrazySC300's Avatar
CrazySC300
Okay, The part number for the entire Shim Kit (All together as one) is "04945‑50012" unfortunately, It'll run you about $100+
Shims (Individually separate) and other parts (Like Springs,Pins,Clips,etc...) you'll probably need (Along with part numbers,The quantity that you need and general retail prices) are as follows...
SHIM, ANTI-SQUEAL, NO.1(FOR FRONT DISC BRAKE)
47745‑50060 UCF20, RH 1 $8.82
47745‑50070 UCF20, LH 1 $8.82
SHIM, ANTI-SQUEAL, NO.3(FOR FRONT DISC BRAKE)
47744‑50070 UCF20 2 $12.81
SHIM, ANTI-SQUEAL, NO.2(FOR FRONT DISC BRAKE)
47745‑50060 UCF20, LH 1 $8.82
47745‑50070 UCF20, RH 1 $8.82
SHIM, ANTI-SQUEAL, NO.4(FOR FRONT DISC BRAKE)
SPRING, ANTI-RATTLE, NO.1(FOR FRONT DISC BRAKE)
47748‑50010 UCF20 2 $10.95
CLIP(FOR FRONT DISC BRAKE ANTI-RATTLE)
90468‑12022 UCF20 1 $1.62
PIN, W/HOLE(FOR FRONT DISC BRAKE ANTI-RATTLE)
47735‑50010 UCF20 4 $25.42
47749‑50020 UCF20 1 $2.53
Old Feb 1, 2012 | 01:51 AM
ScBouncE's Avatar
ScBouncE
holy smokes thats alot of stuff.... its just the front drivers side that makes that noise. Do I really need all of that ? I just want whats necessary
Old Feb 1, 2012 | 08:10 AM
TougeSC3's Avatar
TougeSC3
Is it possible that you are missing the shim kit on the drivers side, but not the passenger? I'd check that out.
maxwebr
Apr 15, 2016 08:27 AM
rob22
Jun 12, 2009 06:31 AM
rob22
Jun 11, 2009 05:34 PM
nysupraman
Jun 22, 2003 03:10 PM
DDLexus
Suspension and Brakes
Nov 4, 2001 01:41 AM
