SC- 1st Gen (1992-2000)
Blew fuses now car wont start?help!
Old 01-13-12, 03:14 PM
Catracho30
Catracho30's Avatar
Default Blew fuses now car wont start?help!
so i forgot to unplug the battery when installing the intrument cluster and some fuses blew.the fuses that blew where the main fuse (60a) and the the ignition fuse (30a).replaced both of them.i have a 1jz/r154 into a 97 sc300.the NSS bypass was working perfectly before this.now the car wont crank and the fuel pump doesnt even start when i turn the key.any ideas at what could have messed up. fuel pump relay? or fuel pump ecu? i replaced the starter relay too and nothing
Old 01-13-12, 05:05 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I have never taken the battery loose for an instrument cluster out of thousands of times and nothing about the cluster, even a dead short, can produce 60 amps of current and blow a main fuse so we need to know what REALLY blew those fuses. The cluster plugs would melt at even 25 amps. More info?
Old 01-13-12, 05:37 PM
bighead222
bighead222's Avatar
Default try that
idk if it would help but i just blew my 120 amp fuse and the car wouldnt start or crank over replaced it and it works fine
Old 01-13-12, 05:54 PM
313sc3
313sc3's Avatar
Check all your fuses. I blew my main fuse. Replaced it and a few little fuses. Now it's fine.
Old 01-13-12, 06:06 PM
Nova
Nova's Avatar
do you hear the relay click? if not check the fuse, if the fuse is blown, check for a short to ground, there is a reason the fuse blew in the first place
Old 01-14-12, 04:01 AM
Catracho30
Catracho30's Avatar
thats all i did or atleast all i recall.
Old 01-14-12, 04:02 AM
Catracho30
Catracho30's Avatar
no relay click.how do i check for a short?im still new at some of this lol
gkane
14
07-25-19 06:11 PM
91ls400own
04-15-16 03:24 AM
Goosesedan
09-28-15 09:34 AM
berumene
Performance
08-28-15 06:53 PM
eyecon7
03-14-10 04:47 PM
Quick Reply: Blew fuses now car wont start?help!
