Is cold air intake really worth it?
Old Nov 16, 2011 | 11:08 AM
MumRah's Avatar
MumRah
o and also having a CAI will give you more space in your engine bay
Old Nov 16, 2011 | 11:23 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
wow this thread is so off track.
By ram air do you mean just sticking a cone filter in the engine bay like on that link? if so you would be sucking in very hot air, I have personally tried it just to see and I actually lost power all over and MPG. the engine bay gets really hot on the exhaust side. There only gain is aesthetic and that is arguable, you will loose performance.
The stock airbox is a cold air intake (CAI). that means at the front there is a tube that goes under the headlight and sucks in cold air from outside the engine bay. This will give you the more power vs hotter air. The stock airbox for an N/A is not that restrictive especially with a drop in aftermarket filter, I have seen turbo setups using the stock airbox even.
The only thing that would be better is a larger cold air intake, which is the BFI cause you are making the area it brings in cold air from larger.
Either that or you extend the piping into the fender area (have to cut a hole under the stock airbox location) and put your cone filter there, that would also give you more cold air, but will be more prone to catching water if you like to take your SC through small lakes.
In summary; More hotter air = bad and more colder air = good
This has been covered a thousand times over. Search is your friend.
Old Nov 16, 2011 | 01:49 PM
DreaMzZ's Avatar
DreaMzZ
Your saying an aftermarket air filter would help more than the ram intake..?
Old Nov 16, 2011 | 02:49 PM
CantSeeMe's Avatar
CantSeeMe
It would be negligable, neither will add a noticeable amount of power if that is your intention. The injen intake will sound a little better, thats about it.
Old Nov 16, 2011 | 06:47 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
that is exactly what I am saying. Even the stock setup is better than the ram air. don't oil the filter though, it will hurt the maf eventually. just run it dry.
try this out, run your car for 30 min, then pop open the hood and put your hand near the distributor (where the injen ram air sits).
This is possibly the hottest place in the entire engine bay. you are loosing valuable power and increasing your chance for knock, which makes the ecu pull timing madly. I have actualy owned all 3 setups.
Old Nov 16, 2011 | 06:58 PM
DubbStep's Avatar
DubbStep
I too agree... plain and simple, keep what you have, 9/10 times its better then after market.... Wanna make upgrades on your car look into suspension mods, nothing better then a tight Lex
Good luck with your hunt tho....
Old Nov 16, 2011 | 07:46 PM
SEXC's Avatar
SEXC
A k&n filter would be my choice, anything else is worthless. I recommend spending your money on bushings and any other maintenance to make it run like new again
Old Nov 17, 2011 | 08:27 PM
1997Soarer's Avatar
1997Soarer
K&N or APEXi or Blitz drop-in air filter + dremeling the airbox = best bang for your buck. I always ran Blitz drop-ins with the BFI. I never went as extreme as the BFI setup is supposed to be; I just dremeled the front of the airbox as big as i could. Later I snaked about a foot of fireproof ducting under the headlight and attached it to a velocity stack that i rigged and mounted just behind the air inlet on the passenger side of the front bumper (97+)
Old Nov 18, 2011 | 04:25 AM
spoolxexo's Avatar
spoolxexo
I looked at the BFI link I dont fully understand it, basically im cutting a hole in box and making some ****** rigged dryer tube to come out under hood?
Chill out on the racial slurs, there Carolina boy...
khizr23
Nov 21, 2018 07:02 AM
darkstar38
Performance
65
Dec 10, 2014 07:38 AM
MrBalistic
Jul 31, 2014 05:56 PM
josh1984
May 9, 2009 12:06 AM
elgreco008
Apr 30, 2007 09:13 PM
