1siksc Flow Brackets
These are just rough copies, i am gonna get a bench grinding wheel so i can form them perfectly. I originally cut the bracts out of cardboard, the ones aluminum cut are laser cut. Also idk if others are interested in these i could possibly borrow someone with a stock sc and get them made for those with a/c.
NOTE: The upper bracket is sitting on my radiator fan bracket which is why it's sitting way to high. Lower bracket, thinking of expanding to be wider. CARDBOARD Cut Out https://fbcdn-sphotos-a.akamaihd.net..._4148788_n.jpg https://fbcdn-sphotos-a.akamaihd.net...51217679_n.jpg https://fbcdn-sphotos-a.akamaihd.net...26795723_n.jpg https://fbcdn-sphotos-a.akamaihd.net...11676010_n.jpg https://fbcdn-sphotos-a.akamaihd.net...98297171_n.jpg https://fbcdn-sphotos-a.akamaihd.net...34642116_n.jpg What do you guys think? Also to NOTE, I will be painting these Brillian Black Crystal Pearl when i finish painting the car. |
i think it will look much better after edges are cleaned up and it is all painted. would also lengthen lower and bring it to a corner over the headlights, seems like an abrupt stop the way it is. for the record your engine bay is plenty sexy without
:D Thanks! I really do want to use them though since i will be using them for function with some more plates to be installed behind intercooler and on the under body, I am trying to optimize cooling and air flow. I agree with you on extending to the first bolt on the lights, i think the reason why i didn't when i was doing the cardboard cut outs is cause of the dip in the headlight bracket.
Nice fab. Yeah after they are cleaned up & perfect,they will look sweet. Man Ive been wanting to get one of my RSB, monstered out. Bar black & feet green just to see it looking cool. Would be a sweet addition to your ride.
Nice work, however hard to tell by looking at it now. I would like to see the finished product.
Also, do you think that your one fan will be enough to keep your car running cool. There is so much area on your radiator that isn't being covered.. |
Originally Posted by spdrcr771
(Post 6816360)
Originally Posted by Wicked SC
(Post 6816403)
Also, do you think that your one fan will be enough to keep your car running cool. There is so much area on your radiator that isn't being covered.. https://fbcdn-sphotos-a.akamaihd.net..._1707093_n.jpg |
