Weird bucking issue
Old Oct 29, 2011 | 03:30 AM
tuobeb's Avatar
tuobeb
Default Weird bucking issue
Ok I just got my 92 sc300 5spd and I've noticed while cruising (any speed). If I let off the throttle and then ease back into it, it bucks/stutters. Any ideas since I'm new to these cars?
Old Oct 29, 2011 | 11:26 AM
JDMJoe239's Avatar
JDMJoe239
sounds like a vacuum leak. i had the same problem.
Old Oct 30, 2011 | 06:27 PM
sj408's Avatar
sj408
to be honest sounds like another tps issue, have you tested the voltage going to the tps? i had this exact same problem for a while, When i would be cruising if i eased into the throttle it would jerk everywhere but if i went wide open throttle it would be less noticeable
Old Nov 2, 2011 | 01:50 AM
DriftSC's Avatar
DriftSC
It sounds just like my TPS issue as well. The good news is that its a relatively cheap and easy fix (~$100 and 1/2 hour if you know what you're doing). One of these days I will get around to doing a DIY for this.
Mine threw a CEL, so you may want to check for codes. This is super easy on our obd1 cars... I think the code was 41. (The engine light turned on just after the car bucked, and would then turn off)
Old Nov 2, 2011 | 07:59 PM
tuobeb's Avatar
tuobeb
Well I've got a better sense of what is going on with it now. When I'm taking off and the idle drops a little too low(almost stall), is when it starts doing so. I can shut the car off and restart and it won't do it anymore. I'm thinking it's the tps as well. It seems it gets "stuck" when it almost stalls, but when you shut the car off it "resets" its self.
Old Nov 2, 2011 | 08:01 PM
tuobeb's Avatar
tuobeb
No CEL either when this occurs.
Old Nov 3, 2011 | 09:50 AM
sj408's Avatar
sj408
it usually doesnt for tps.... go to any reputable shop and ask them to datalog the car and see what sensor isnt firing right. bet its tps
Old Nov 14, 2011 | 09:36 PM
tuobeb's Avatar
tuobeb
Well it's a little late, but I replaced the tps. It fixed the issue with the bucking. Nice five minute repair and $68 dollars later, but the car runs great now.
Lena
May 24, 2019 05:38 AM
3sdsmer
24
Jun 6, 2013 02:39 PM
rli2bcz
Mar 25, 2009 10:57 PM
TJW98LS
Jul 1, 2008 11:50 PM
KingNasGS4
30
Aug 24, 2007 06:49 PM
