headlight
Old Aug 14, 2011 | 05:20 PM
showgun82's Avatar
showgun82
Default headlight
can Someone help please, my head lights stay on when the car is off and the switch is off....had to pull the fuse just to take off the light . any one to fix this?
Old Aug 14, 2011 | 06:26 PM
CrazySC300's Avatar
CrazySC300
Does this happen when you shut the car off completely? I sorta randomly had this problem myself...It would turn off when I shut the car off completely...I'm thinking it's the ECU trying to relearn something...I'm not sure, Sorry I couldn't be of anymore help.
Old Aug 14, 2011 | 06:33 PM
blacksc4's Avatar
blacksc4
nvr heard that problem before, try unplugging ur battery for about 30 mins and put it back on and see if it changes
Old Aug 15, 2011 | 03:16 AM
showgun82's Avatar
showgun82
the light stay on when the car is completely off.....i did unplug the battery for 2hr and same issues....
Old Aug 15, 2011 | 04:00 AM
NerdRiot's Avatar
NerdRiot
Is your car lowered? If so, did you relocated your wiring harness?
Old Aug 15, 2011 | 04:02 AM
showgun82's Avatar
showgun82
not lowered...did not touch the wire harness
Old Aug 15, 2011 | 06:14 AM
xwingzero2's Avatar
xwingzero2
I'm with you on this one. I think its the ECU as well
Maybe the ECU's main relay is on with the key out of the ignition, so try wiring a switch in to cut power to the main relay.
Old Aug 15, 2011 | 10:49 AM
arbalist's Avatar
arbalist
does your dome light come on when you open the door and its set to "door".
ive seen this happen when the door switch is broken. The body's ecu gets confused and "thinks" you are still in the vehicle, so it doesnt set off the timer to deactivate the lights after x seconds.
Old Aug 20, 2011 | 12:32 PM
showgun82's Avatar
showgun82
the dome light is set to door and the light do come on when the door is open..and shut off when its close....
where is the main relay for the lights?
Old Oct 19, 2013 | 09:48 AM
zneubauer's Avatar
zneubauer
I got the same problem, wondering how to go about the possible door issue?
Old Oct 19, 2013 | 04:07 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Must be a Florida issue with the headlights.. LOL
2ndGen3
Feb 26, 2018 07:17 PM
TexasSC
Jul 13, 2014 02:37 PM
LEXUS714
Apr 8, 2012 09:50 PM
bowen.chau
RX - 1st Gen (1999-2003)
16
Feb 15, 2011 08:08 AM
TLW
Maintenance
Mar 30, 2006 08:35 AM
