***HELP*** radio & electric side mirrors don't work.??
Hi, Im having issues with my new 94 SC300.
The radio will not turn on and the antenna is stuck on the halfway position. My side mirrors don't work either. I got the car his way so not sure what the original owner did to the car. I checked the fuses but they're all fine. I did a search on the forums and didnt find anyone else hat had these same issues. Not sure what's going on..? Please help! Thanks in advance! |
check relays
Side mirrors, if it ain't the fuse, it must be the ECU for the side mirrors, mine got the same problem, it's around $40 at eBay..
Thanks guys!!
do you have aftermarket rims or are you lowered, if so check your drivers side harness above the tire
| All times are GMT -7. The time now is 10:20 AM. |
