ls400 bbk question
Old May 13, 2011 | 11:35 AM
cheez's Avatar
cheez
Default ls400 bbk question
i found come stoptech drilled rotors online for ls400. but there are 2 different size of rotors. first one has a diameter of 12.09 inches and a height of of 2.67 inches. second option has a diameter of 12.40 and a height of 2.09. can anyone confirm what the correct size is? heres the linky http://thmotorsports.com/stoptech/st...d/g-55256.aspx
Old May 13, 2011 | 11:42 AM
SChema's Avatar
SChema
You'll need the 12.4" rotor, try to get "slotted" only rotors if possible; that is if you're looking for performance.
Old May 13, 2011 | 11:50 AM
cheez's Avatar
cheez
thanks so much
Old May 13, 2011 | 12:05 PM
empera's Avatar
empera
what years do the rotor size change? and are they interchangable?
Old May 13, 2011 | 12:17 PM
SChema's Avatar
SChema
1995, No they are not interchangeable, in terms of only rotors.
Old May 13, 2011 | 12:23 PM
cheez's Avatar
cheez
ok i just ordered them and supra tt for the rear, both drilled stoptech, now all i need are the calipers for a decent priceeeeeee
Old May 13, 2011 | 12:41 PM
empera's Avatar
empera
so 1995-2000 are the brakes/rotors u want if u want to upgrade your sc brakes?
Old May 13, 2011 | 12:55 PM
cheez's Avatar
cheez
for the front brakes. not sure about the rear but im doing supra tt in the rear
Old May 13, 2011 | 01:46 PM
SChema's Avatar
SChema
^, You'll like the TT Rears.
It corrects the slight change in bias when doing only the fronts.
I did mine soon after doing the fronts.
Old May 14, 2011 | 10:41 AM
maceugood's Avatar
maceugood
im not ready to put bbk on yet cause im still waiting to get wheels, but my stock rotors are warped, can i put these rotors on and use stock calipers till i am ready to put LS calipers on?
Thrustn
Dec 5, 2016 12:52 PM
jaxtheax
Aug 30, 2014 11:38 PM
NEbiker10
Mar 6, 2011 12:23 PM
andrewwake
Oct 13, 2007 10:11 PM
Wald GS
GS - 1st Gen (1993-1997)
Aug 31, 2005 10:16 AM
