Testing the MAF, checking my reasoning...
Old May 11, 2011 | 03:03 PM
MuGGzyx's Avatar
MuGGzyx
Default Testing the MAF, checking my reasoning...
In troubleshooting my stuttering/hesitation issues I thought I had eliminated the MAF as the culprit when I unplugged it and the problem didn't change. Initially I thought "oh if it was that, the car would go into the 'emergency mode' and go full air/fuel mix and the problem would go away", well when I unplugged it, and the issue didn't change, I went on to throw a pile of money at other things, that did NOT solve the issue,
FINALLY I found the thread on here regarding the Hesitation issues with info on how to test the MAF with a multimeter and found a friend I could borrow one from.
When I tested it, it had no resistance or constance at all, I could have been testing a GD Q-Tip for all the response the meter gave me. I tested the two far right pins in the MAF socket, as well as every other combo I could for that matter, and got zero reading, like I was stabbing the probes into a dinner roll.
So, before I throw yet more $$ at this thing, my thinking is thus...
If the car was running like ****, and it was because the MAF was totally dead or burnt out, unplugging it wouldn't have any results anyways since the ECU pretty much assumed it was gone anyways.
At this point I have done everything I could find to do on here and a couple other sites and the only thing I haven't straight up replaced is the MAF sensor.
Old May 11, 2011 | 03:31 PM
TLDriver's Avatar
TLDriver
was there a check engine light?
Old May 11, 2011 | 03:33 PM
TechGreek's Avatar
TechGreek
If you unplug it and reset the ECU (via the fuse in the engine bay) does it make a difference?
Old May 11, 2011 | 06:35 PM
MuGGzyx's Avatar
MuGGzyx
Never had a CEL and I have reset the ECU several times at this point.
Old May 12, 2011 | 06:11 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
just saw this thread, you should get resistance from the maf.
check out the chart if you haven't seen it on post #6.
https://www.clublexus.com/forums/per...-92-sc400.html
Old May 14, 2011 | 10:45 PM
93twintrbo's Avatar
93twintrbo
Unfortunately Doing a resistance test to check a Mass air flow sensor is not a proper way to test. Best way to test is to check it with a lab scope and measure the voltage during a snap test. However testing resistance values will only tell you if the maf sensor is dead or highly damaged.
I would recommend taking the car to a competent automotive shop for a diagnostic. In the end its cheaper than thowing parts at the car.
Old May 16, 2011 | 01:28 PM
MuGGzyx's Avatar
MuGGzyx
Thanks Ali! I have a MAF from you sitting at home on my porch, I hope/expect this to be the issue since the existing one is a dead hunk of plastic and I have tried a known good ECU.
BartleDoo
May 23, 2013 09:24 AM
willfxp
Feb 27, 2011 03:30 PM
RedPhoenix
Jul 22, 2009 10:53 PM
Dereke
42
Jan 23, 2009 03:02 AM
Dx3
Apr 28, 2006 03:54 PM
