Line Lock's & brakes
So I'm thinking i want to install a line lock, Have any of you done this? and is it hard? looking for any input at all
Also going to start to learn drifting so any tips would be nice also going with my break questions. how does my ebreak actually work? if i were to disable and seal the rear lines from my abs station, will my ebrake still work? and could i still drive around town safely while running only front brakes? i know some of these may be stupid questions, but i have never owned a car with 4 wheel disc let alone abs so i dont know and would rather have an idea before i do something retarded and get myself or someone else hurt. |
not sure whts goin on here haha not my scene of the car parts
BUT i will say from experience running jus front brakes is ok as long as theres no precipitation on the ground cuz keep in mind you running a rear wheel drive car and 80% of ur braking comes from the rear so u will have less stop time and can be relatively dangerous. living in ohio i had no rear brakes due to a master cylinder fail for 3 months and there was snow... bad mix alot less stop time so i had start braking much before needed kinda depends on location on your driving style |
Parking brakes are cable actuated so they will still function even with the line lock on. The line lock won't permanently disable the rear brakes, in fact, its not even for the rear brakes. Here is the product description from Hurst's site:"What exactly does a Line-Lock, Brake-Control Kit do? Here is how it works: Press the brake pedal an hold the roll control Snap-action switch down. Remove your foot from the pedal, and the solenoid maintains line pressure to the front brakes until switch is released. This makes it easy to heat the rear tires in the burnout box, while minimizing wear and tear on your cars rear brake components. You can also use the system to prevent a manual-trans car from rolling out of the staging beams at the starting line. Weather you call it a roll control, line lock or roll stop. A Brake-Control Kit, will keep your vehicle out of the staging lights before your ready to launch."
I think he means a hydraulic e-brake, not a line-lock
basically I want to be able to turn off my back breaks with a on off switch but have my ebreak work at all times.
How can i do this? this way when drifting i can drive around the track with the auto trans and slow down the car without slowing the rear tires also when I'm at bandimer speedway i will be able to burnout in the box before a 1/4 drag |
Your e-brake is independent of your actual rear brakes. Anything you do to the hydraulic part of the system will not affect your e-brake.
It is not okay to run with only front brakes, it completely throws off the brake bias. Not safe whatsoever, you will put your life and others at risk. Any vehicle will still need rear brakes to keep the rear of the car tracking straight when coming to a stop. |
Originally Posted by Adaa60
(Post 6279228)
How can i do this? this way when drifting i can drive around the track with the auto trans and slow down the car without slowing the rear tires also when I'm at bandimer speedway i will be able to burnout in the box before a 1/4 drag The purpose of having a line lock is for two main purposes; burn outs for getting be best traction off your tires before a run, and keeping your car on the starting line so you can build power. If your learning to drift, try this in an appropriate place where nobody will get hurt. Since you have an auto transmission, O/D off. Before you enter a corner use your brakes to shift the weight of the car to the front, drop down to 2nd gear, get off the brakes, turn the wheel, and power over. If you have an open diff. grip might not be that great but work at it with practice. Try some left foot braking techniques if you find yourself slow at the transitions. |
Auto drifting doesn't require modifying your brakes lol. The only purpose of a line lock is for doing burnouts. If you only want an ebrake and don't want normal hydraulic rear brakes, then just pull the line off and cap it off or something, but disabling your rear brakes is one of the worst ideas I have ever heard of.
To drift in an auto you need power and weight shifting since you don't have a clutch. You should also have a welded diff or lsd. I really doubt you will have enough power in a stock sc400. |
| All times are GMT -7. The time now is 01:05 PM. |
