ground, tps? I'm stumped
Old Feb 21, 2011 | 12:35 PM
  #31
DRFT103's Avatar
DRFT103
Ok a little update, I cleaned all of my grounds in the engine bay and added two 4G grounds to the car. One from the block to chassis, and one from the chassis to the intake manifold. Since then, the car WILL NOT die anymore at idle.
I'm still getting some annoying misfiring under boost, and still can not get into good boost
I wonder if I should just add even more grounds?
Old Feb 21, 2011 | 12:50 PM
  #32
1WILLY1's Avatar
1WILLY1
well im no mechanic but if adding some grounds worked a little add some more and see what happens.
iom glad to see you made at least some progress here though --congrats and good luck once again
  #33
stockhatch's Avatar
stockhatch
Add a fresh ground to replace the one that you said you may have overloaded.
Old Feb 21, 2011 | 01:45 PM
  #34
DRFT103's Avatar
DRFT103
Well, The way I think of it, even if the ground kit doesn't solve it... it's still a good upgrade for when it does run properly again (if ever lol).
A local audio shop sells 0 gauge wires by the foot, and they put copper eyelets on the ends, I'm just gunna do a custom grounding kit and see what happens...
battery to chassis
block to chassis
intake manifold to chassis
transmission to chassis
Even if it doesn't cure it, I'm sure it would be good to have regardless.
any other good spots?
Old Feb 21, 2011 | 03:31 PM
  #35
stockhatch's Avatar
stockhatch
Ok, now that I think about it.... is it possible to melt a ground?
when my car was running great about a year ago, I bought an AEM tru boost gauge and wired it up to the same ground wire on the ECU that my map ecu and AEM wideband, so I had two digital gauges AND the MAPECU running off the same little 16ish gauge ground wire to the ECU. The car ran fine for a day, the next day I noticed little hiccups at full boost, the hiccups got progressively worst over the next few days to the point where my car barely started..
Since then I've wired the gauges to the radio where my MAPECU was the only thing running off of that wire.
It started up and drove much better than before, yet it wasn't all the way fixed, because i'm still having these problems.... Could I have messed up that one ground wire somehow?
You said that ^^^^^^ Which is why I said this VVVVVVVVV
Have you tried that yet?
Old Feb 22, 2011 | 12:43 AM
  #36
DRFT103's Avatar
DRFT103
I'm definatly down to try it... but how do I do that? are you suggesting I replace the entire wire? or maybe tie in an extra wire to that one and grounding it?
Old Feb 22, 2011 | 05:01 AM
  #37
stockhatch's Avatar
stockhatch
Yes, I would find a spot on the chassis, and run a ground from the chassis to where that ground ends. I think you said at the ecu? What pin is that wire on and I can tell you exactly where it goes. Maybe replacing it entirely would be feasible.
Old Feb 22, 2011 | 06:57 AM
  #38
99SC42's Avatar
99SC42
Pin 79 and 80b at the ecu are grounds my car will not run w/o me running a wire from 79 and 80 and ground it at the chassis lol.
So did ground the (2) grounds under the intake manifold?
Old Feb 22, 2011 | 07:58 AM
  #39
DRFT103's Avatar
DRFT103
the ground i used was B69
if you can tell me where that wire goes, (I think it's the rear ground on the intake mani) I can check for continuity from where it starts and ends.
as for adding a new ground... Do I just tie in a new wire about an inch away from the ECU plug and ground that wire? I have no idea how to replace the entire wire, getting a new wire in the plug would be my biggest problem
Old Feb 22, 2011 | 08:59 AM
  #40
stockhatch's Avatar
stockhatch
You must mean A69. It goes to the "rear of cylinder head" according to wiring diagram. It also splits off and goes to pin 3 "E1" on the diagnostic connector. Yes, I guess you could just tap the wire near the ecu plug if you run another.
Old Feb 22, 2011 | 11:47 AM
  #41
DRFT103's Avatar
DRFT103
Ok, another question... Today I went out to crank my car, and it wouldn't start.... after trying and trying I finally got it to start... and it ran like crap, horrible idling and missing, and when I revved it to 2,000 my friend standing over the engine bay thinks that he heard rod knock.... But i've never heard it before.. So my question is... could rod knock be my problem?
would the ecu detect rod knock at idle and shut the motor off? I know it enters fail safe mode and retards the timming but... would it cause my original symptoms?
shutting off randomly, missing at boost, random shutting down at boost etc...
Old Feb 22, 2011 | 12:04 PM
  #42
99SC42's Avatar
99SC42
Damn dude this is what i would do remove all those stuff off and get it running on the stock ecu first.
You will be chasing your tail at this point because you are not even sure if all those parts were installed correctly.
Ecu will not detect any rod knock ......
Old Feb 22, 2011 | 12:21 PM
  #43
DRFT103's Avatar
DRFT103
I can't do that for so many reasons it's not even an option...
when going NA-T I deleted my MAF and threw it away, the car runs on MAP now.
I also cut up the harness and wired in a MK4 resistor and 580cc injectors. I dont have stock headers or 02 sensors or anything.. it just can't be done at this point.
To my understanding, there are two knock sensors on the car, when the ecu detects the knock, it will put the ECU in a fail-safe mode and retard the timing so that you don't blow your motor, maybe when that happens my mapecu2 fuel trims are so off that it kills the car because it's not tuned to those values?
Old Feb 22, 2011 | 03:41 PM
  #44
1WILLY1's Avatar
1WILLY1
sorry man sounds like your back at square one again----you might have to bite the bullet and drop the car off at a top notch mechanic and hope for the best, see if he comes up with something.
Good luck
Old Feb 23, 2011 | 09:42 AM
  #45
DRFT103's Avatar
DRFT103
So I'm completely discouraged and completely over this car, I'm thinking I'm going to sell most of my NA-T parts and just swap in a GTE and be done with this car... I won't have nearly as much power but atleast I'd be able to drive it....
Thanks to everyone who helped out...
Probably going to put up my MAPECU2, Precision billet 6262 ball bearing, PTE 580cc injectors, manifolds ect... up for sell soon, so if anyone wants some parts for cheap, now's the time! haha
