first motor pull !!! any tips?
Old Jan 26, 2011 | 08:40 PM
chnk's Avatar
chnk
Default first motor pull !!! any tips?
I bought a cheap sc400 for parts a while back and I want to pull the motor out of it,
any tips on how to actually get this done?
I have a motor lift, basic tools, and an impact wrench.
How hard it it to pull the motor from an sc400 espically for a first timer?
Ive put in coilovers and done maintenance on the car that about how fa my experience goes
My weekend plan I need opinions on this
ok I have two 2 sc400s at the moment, a 92 red one and a 95 white one
I ran my white one up a curb one night about a 2 months ago and has been sitting every since. Here is a link btw https://www.clublexus.com/forums/sc-...-diagrams.html
The resulting damage from what I could see was
a cracked upper oil pan,
the lower pan silicone seal gave way and will need to be resealed
the subframe got a good chunk ripped from it and is cracked
I recently bought a non running 92 sc400 for $760
I plan on keeping the motor n tranny for parts or backup and I plan on swapping the following parts
upper oil pan
maybe lower oil pan,
subframe
steering rack
Why not get the 92 running, it was side swiped in the passenger and the rear quarter panel has lots of bondo. Windsheild is cracked plus I simply do not like the color. Interior is trashed, paint is trashed, too much work. My white 95 sc has a color im in love with, a nice non ripped interior and paint is good for its age. Plus I've done lost of tedious fender work to get my 19s to fit
I have one engine lift or cherry picker, and two motors that will be needed to be held up to swap subframes. That simply wont work.
So my weekend project will be to pull the motor out from the 92 making easy access to the subframe, oil pan, and steering rack
Second use the lift to hold up the motor in the 95 while I put in the oil pan, subframe, and steering rack.
This will my first time doing any of this. I have some help from my cousins who are mechanics.
Old Jan 26, 2011 | 08:44 PM
mak89's Avatar
mak89
Please someone with experience give advice, even for a sc300/2jz.
Old Jan 26, 2011 | 08:50 PM
chingpo05's Avatar
chingpo05
the motor is extremely heavy so be careful. get a engine leveler to make jobs way easier. drain all you fluids, remove radiator/fans, use a 2 post if its possible
Old Jan 26, 2011 | 08:55 PM
PJ82ND's Avatar
PJ82ND
u have a cherry picker or a lift?? removing engine on sc are very simple u dont have to remove harness from engine unplug from ecm and up it goes remove bolts from flywheel loosen bolts from bellhousing loose engine mounts bolts remove radiator loosen bolts for exhaust exhaust manifolds stay with engine u'll need a 10,12,14,17 swivel 17mm socket n swivel 14mm socket n cold beer n good music n have at it :-)
Old Jan 26, 2011 | 09:00 PM
chnk's Avatar
chnk
thanks didnt think of draining my fluids that wouldhave been messy
whats a 2 post?
i dont know im borrowing it from a local guy, i thought they were the same thing,
ok this might sound stupid but when u say loosen u mean completely remove?
Old Jan 26, 2011 | 09:09 PM
meangreen1's Avatar
meangreen1
Yeah, get a buddy to help you. 2nd, an engine leveler is where its at.
Old Jan 26, 2011 | 09:14 PM
chingpo05's Avatar
chingpo05
2 post lift.. are you planning to pull just the engine or the transmission with it? if you are pulling the entire engine with tranny then put the car on 4 jackstands bc you will need the clearance when the engine+tranny are tilted to come out. if not then do what pj82nd said. if you don't have mechanical experience i wouldn't tackle this alone though. it seems the guys that post on this forum have lots of experience around cars more than other forums i have been on. i am a mechanic so these type of difficulties come with the territory the only thing we have to look forward to in the profession is comparing how a certain job aren't as hard as others such as the cursed bmw or crappy domestics. have fun and take pictures and take breaks when you get angry.
Old Jan 26, 2011 | 09:17 PM
chingpo05's Avatar
chingpo05
2j's are less bulky so its a bit easier to maneuver in and out compared to its wide v8 brother
Old Jan 26, 2011 | 09:39 PM
chnk's Avatar
chnk
ok thanks
Honestly i was contemplating this,
upper oil pan
subframe
steering rack
6SOARER's Avatar
6SOARER
I just did my first engine pull today. Everything went smooth but Im having a tuff time getting it back in.
Tips pointers:
Do drain all your fluids-coolant, oil, trans oil. I thought I had all the trans oil out but when I tilted the engine to get it out. I had a puddle of trans fluid all over the driveway.
Make sure you have all the necessay harnesses are disconnected. Dont forget the throttle cables.
If you can have someone help up an extra hand is always useful.
Old Jan 26, 2011 | 09:48 PM
chnk's Avatar
chnk
Tips pointers:
thanks I dont plan on putting the motor back, gl getting u motor back in
edited my first post to include my weekend plans
JustChill
Dec 30, 2011 09:57 AM
iridebmx
SC400 / 300 Classifieds
18
Oct 13, 2010 05:11 AM
aliga
Aug 24, 2010 06:18 AM
Jrtoxic
Dec 13, 2008 12:41 PM
tracyrene'
Apr 22, 2007 04:35 AM
