ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   Meangreen1's GT35R build. (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/542780-meangreen1s-gt35r-build.html)
meangreen1 Dec 21, 2010 04:20 PM
1 Attachment(s)
So after making sure I have everything I can think of, I will be starting my build on the 26th.
Heres the car.
meangreen1 Dec 21, 2010 04:30 PM
2 Attachment(s)
Car specs right now.
1JZGTE
Factory 5sp
FMIC
3" full exhaust
DYNO #'s 302TQ, 273.5 RWHP @ 9lbs
meangreen1 Dec 21, 2010 04:39 PM
1 Attachment(s)
List of parts
(1) GT35R Garrett DBB.
(1) 3" downpipe
(1) 4" intake
(1) Driftmotion exhaust manifold.
(1) 24" -4an to -4an 90 ss oil feed line.
(1) 3" to 2.5" sli 90.
(1) Turbosmart wastegate.
(1) BOV
Alu. tubing to finish hot side.
Fittings, flanges, gaskets, ect.
(1) 255lpm fuel pump
(6) 600cc injectors (side feed)
In the mail
Larger FMIC. 31x12x3
fittings.
I am sure theres more, but I cant think right now. :p
jadu Dec 21, 2010 04:48 PM
oooo gl with the build! keep us posted and have fun
meangreen1 Dec 21, 2010 05:04 PM
The only question I have is about the oil drain line. I have a An-10 pan fitting from Driftmotion. I just dont know about the drain from the turbo. Getting it through the runners doesnt look fun.
99SC42 Dec 22, 2010 05:41 AM
DO not run the oil return in between the runners don't do it.
Ali SC3 Dec 22, 2010 08:19 AM
^^^ listen to this man, clock your turbo's center section slightly, use a 45 degree off of the drain flange or whatever you need to clear the runners completely. running it through the runners may lead to problems down the line...
99SC42 Dec 22, 2010 08:50 AM
The car will catch on fire no BS here i am very serious don't do.
That's why i scratched my 1JZ single project, because the oil return wouldn't clear the manifold, or the WG won't clear the DP.It was too much for me lol.
TURBO819 Dec 22, 2010 09:19 AM
2 Attachment(s)
They are right. You might want to look into using Metal Tubing for routing of the Oil Return See Pictures
SC51 Dec 22, 2010 03:52 PM
quickGS300 The car will catch on fire no BS here i am very serious don't do.
Goddd exactly lol I really don't know why companies make things the way they do, I guess to keep us thinking. Its like rite when you get your new parts on thinking easy install, you have to modify this and that and customize ***** :p
meangreen1 Dec 22, 2010 08:11 PM
Thanks for the input guys. I was planning on using a 1/2" ss pipe that I can make at work. I make sure to let you guys know what I did.
Also
What about a braided stainless line? Do you guys think it would work?
meangreen1 Dec 22, 2010 08:14 PM
Originally Posted by Turbo_LX (Post 6012971)
OP what wheels are those? They look really nice.
Correct me if I'm wrong... are those SSR?
http://www.ssr-wheels.com/wheels/werfen_181920.asp
You have the style correct, but not the brand. Trust me, I would love some SSR's, but am afraid of them getting jacked. Also my wife curbbing them.
If you must know, there ASA. Offsets are okay. 33/35. I am running spacers also
99SC42 Dec 22, 2010 08:24 PM
I am using my phone right now but tomorrow I will post some pics on your thread to show you what you need to get its really easy and you will be happy with the results.
I have seen a car caught on fire from a hack up job on the return line.
Ali SC3 Dec 23, 2010 09:27 AM
Also
I use braided stainless steel line for my return, but it doesn't go through the runners. works like a champ.
I don't care what material its made out of never run it through the runners, hardline or not.
you can clear most runners with the right fittings and some clocking, but be sure not to use more than a 45 degree fitting.
