It's finally installed!
Just wanted to let you guys who've helped me with this install know that it finally works - the Apexi Rev/Spd meter.
All functions appear to be working and - more importantly - no warning lights or strange behaviour from the ECU. Gonna see how good the Apexi works now ... Thanks again. |
Congrats Acc...I bet ur finally relieved to get it working properly
in your opinion was it worth it? im thinking of using this as a cheaper replacement for my burnt out speedo and tach on the dash
I personally wouldn't use it for that purpose, although so far I like it. The display is easy to read, and you can choose several different display modes (graphic or numeric), so I guess you could use it as a replacement speedo.
I didn't get it to display those numbers though, I was looking of something a little more sophisticated than the G-Tech. If you need more detailed information, check out their online manual at http://www.apexi-usa.com/productdocu...SpeedMeter.pdf |
