W58 SC 400 long term report
Been driving my SC400 with the W58 swap for a few months now. So far so great. I am very glad I did the swap. The car is far more responsive and is a dream to drive. I had a minor vibration issue that I have figured out. It was most noticeable at 2000 rpm and at over 85mph. It was there whether driving, or at a standstill in neutral. I thought that maybe the flywheel/pressure plate may have been out of balance and had it balanced. The balance shop found that it was good, but did a couple of gram adjustment anyway. Put it back in and still had the vibration. I looked a little deeper at my swap and discovered that I had not cut out enough of the transmission tunnel to fully clear the shift linkage. This improved the situation, but I still had the vibe. While I was messing around with that I packed a lot of closed cell foam around the shifter area. This really made it quiet. So the next thing I did was replace the transmission mount with a new toyota part. BINGO, no vibe, silky smooth just like It was with the auto.
I had looked at the mount when i did the install, but it looked perfect. A side by side comparison of the old and new showed the old was about 1/4" shorter or crushed. Not much. The rubber looked about the same. So it seems as if the rubber had fatigued and wasn't able to absorb any vibration anymore. I think it would be a good idea to put in a new tranny mount when doing the swap. I did think of that, but never did order the part, and did a bit of goose chasing that could have been avoided.
Thanks for the report!
i will maybe also swap to M/T, but before this, i will install the IMF Headers and a LSD
Is the w58 a good transmission for the 1UZ? i calculated max speed 244km/h with the W58 and original end gear. Is the SC in the lower gears faster? Or only more shifting?
One question more...how fast is your SC form 0-60mph? you are ever measured?
thanks!
Tom
thanks!
Tom
thanks!
Tom
thanks!
Tom
I have done 155 in mine with the stock 3.92 rear end and completely stock engine (even stock exhaust with only gutted cats). That was calculated based on tire size, gear ratio and RPM. I also ran a 14.8 quarter my first time ever at the strip, but I didn't get a best time because we got to the track late. I believe the best current would be at least a 14.6 based on my 60 ft time's margin for improvement.
Yea, that's definitely more accurate for your setup, but our numbers aren't really comparable since none of your runs were done with the w58/3.92 setup. I just thought somebody might like to know some relatively accurate data on the w58 with stock motor and differential gearing.
resurrect!
mtnrat, when you did your headers what did you do to the rest of the exhaust system? I have the same IMF headers and I lined them up with the stock manifold, seems like the upstream 02 sensors won't reach that bung on the IMF and instead the downstream 02 sensors would be a better reach? Also, want to know what you did with the cats, since the IMF's are a tad longer, those cats need to move further back, for lowered sc's that's not good i guess.
resurrect!
Yes, they do delete the cats. I'll probably end up hacking the stock Y to fit 2 cats and then meet at the x. Only thing I don't like about the IMFs or any other extractor for the 1UZ is to do a clutch job you'd now need to loosen the passenger side header too since the trans gets caged in by the collectors.
