Second blowout, same wheel, and inner sidewall... WTF
Old Nov 14, 2010 | 04:46 PM
SH_JZZ30's Avatar
SH_JZZ30
The 18" G35 wheels are 18x8 +30 all around. They just have staggered tires on them. Since you have the wheel off, you can look at the inside and it should say.
With the temperatures dropping, it's a good idea to check your tire pressure more often. Hitting a pothole can also cause a bubble on the tire especially if it's an old dry tire.
Old Nov 14, 2010 | 05:03 PM
myke441990's Avatar
myke441990
I'm pretty sure the fronts and rears are different... Anyone else care to chime in about G35 18" wheels?
I wish I could afford new tires...
Old Nov 14, 2010 | 05:17 PM
myke441990's Avatar
myke441990
Guess they are the same size... Sorry about that. I remember reading a thread recently on some guy picking up some g35 wheels and said he had 3 fronts and 1 rear... which wouldn't make sense now since they are all the same size?
Old Nov 14, 2010 | 07:30 PM
kwg's Avatar
kwg
the 17" and 19" front and rears are different. .5" wider and +3 offset.
Old Nov 14, 2010 | 07:53 PM
justin1642's Avatar
justin1642
happened to me and when i took my wheel to belle tire to get a tire put on they replaced the valve stem because it was leaking which caused my tire to lose pressure over time and lead to a blow out.
Old Nov 22, 2010 | 10:08 AM
10GSMAN's Avatar
10GSMAN
Hmmm, I having to buy the 2nd set of rear tires for my wifes IS 350, the inner tread of the tires (about 1/4 inch) are wore down to the wire inside the tire. I have never seen a tire wear like this before. Has anyone else had this same issue or is it just me?????
Old Nov 22, 2010 | 11:17 AM
Tabaka's Avatar
Tabaka
^ what tire brand? Is the IS lowered? When was the last time you got an alignment?
Old Nov 22, 2010 | 09:19 PM
hovsc400's Avatar
hovsc400
yes i have been there too..not to mention tire had good thread left on them but they were goodyears rs-a and there was a recall on them for splitting like dat...get sum new rubber who knows wht the last guy did to them tires
Attached Thumbnails Second blowout, same wheel, and inner sidewall... WTF-imag0014.jpg
Cwang
Mar 21, 2019 08:59 PM
Nellyhx
Jun 21, 2011 10:47 AM
ALLWiTE2JZ
Dec 11, 2009 05:24 PM
TMaxxTim
Apr 2, 2005 11:34 PM
persian451
Nov 8, 2003 02:53 AM
