92 sc300
Old Oct 7, 2010 | 09:32 AM
slippery64's Avatar
slippery64
Default 92 sc300
i am having a problem removing my front brake rotors. have everything off pounded with hammer but can`t get to budge. is there any hidden screws or bolts i need to know about thankyou...
Old Oct 7, 2010 | 10:50 AM
imDementeD's Avatar
imDementeD
mine were a pain in the *** trying to do it like ur doing it..
HOWEVER
theres two spots where you can screw a bolt into..and it pops it RIGHT off..after an entire day trying to break my rotor loose i found a bolt to fit and literally took 5 secs to do..
im not positive the size that goes there but i luckily found one to fit first try
Old Oct 7, 2010 | 01:03 PM
S142jz's Avatar
S142jz
the only thing you can try is a sledge hammer.
Old Oct 7, 2010 | 01:15 PM
Tabaka's Avatar
Tabaka
Brake cleaner is your friend spray around the outside hub and inner side of the hub.
That's where the rust and corrosion has built up over time and makes it difficult to remove. I recently did mine and it was a pain. Make sure you have your e-brake released. I had mine up and fought with the rears for 20 minutes before realizing lol.
Old Oct 7, 2010 | 03:15 PM
t70 supra's Avatar
t70 supra
5 lbs rubber hammer bro just makes it easy had to do it to my rears
Old Oct 7, 2010 | 03:18 PM
gtsfire's Avatar
gtsfire
^^^ THIS is how you do it. Don't beat on it. I used a bolt with a 10mm head. There's plenty like that on our cars.
Old Oct 7, 2010 | 03:23 PM
0435's Avatar
0435
Agreed, please do that. If it doesnt come off with two hits of a rubber mallet, spray some blaster and use those bolts.
Reesetrict
Jul 24, 2012 10:49 AM
picomode
RX - 1st Gen (1999-2003)
Mar 30, 2009 05:19 PM
dusouth
Oct 25, 2007 11:35 AM
1cardfan
Maintenance
May 31, 2006 04:49 PM
lexsc3
Jul 14, 2004 09:31 PM
