camber problem
Old Jul 11, 2002 | 05:54 PM
1BomexLex's Avatar
1BomexLex
Default camber problem
yo guys.. i have a problem wiht my camber still
my rear tires are eating away in a month
i need to fix this problem and soon
is there any kind of camber kit for our cars?
i have lowered my car 1''
but i had the problem even before i lowered it
or maybe there is someone that can fix it
i had my wheels aligned.... taht wasnt the big problem
someone help me out please
peace = Ian
Old Jul 11, 2002 | 05:56 PM
AutoCoutureSC's Avatar
AutoCoutureSC
oh man, you had a problem before you got it lowered? i have eibachs with mine, and of course there's an alignment problem, but i alway get an alignment after 6 months. they say every year, but with 18's, and soon to be 19's... i always do it every 6. was your car involved in a accident before? could be the arms...
Old Jul 11, 2002 | 06:19 PM
ACleanSC4's Avatar
ACleanSC4
Yep, if it was messed up even before you lowered it, there is a big problem there. Have you had your car aligned? They can usually tell you what's wrong with it.
If it's your control arms, you might as well swap the Lexus arms with the Supra TT arms! I can't wait to do that along with the Supra TT shocks & springs.
Tony
Old Jul 11, 2002 | 06:28 PM
AutoCoutureSC
tony, does the control arms really do anythign to the SC? also, share some info with me about the supra springs. i need to lower it more now with 19's. will it work with no problems?
Old Jul 11, 2002 | 07:12 PM
pcmw's Avatar
pcmw
trudremz16,
Did you get it aligned?
If yes, did the guy say it couldn't be fixed?
You said you 'i had my wheels aligned' but you cannot "align" wheels...only balance them. Not sure what you mean by that.
Just for info.
Alignment = setting the suspension components to aim the wheel in a straight line while keeping the wheel geometry so that the contact patch is square on the ground.
This is not done on the wheel...but on the suspension
Now, the problem with lowering a car is that it takes it out of factory spec. Shops that align your vehicle using a computer, usually set your car BACK to these factory specs.... In Sacramento we have a shop that sets the car by hand and eye to the correct settings for the car as it sits. You may need to find a front end shop that can adjust your car to the correct angles.
Good luck
Old Jul 12, 2002 | 01:06 AM
1BomexLex's Avatar
1BomexLex
well ... i did the whole alignment thing
70 bucks or so ... they said that one of the tires was off a little bit
but he put the little red things with points aound the wheel... turned it half way... and then started messing with the suspension
if alignment means gettin the whole tire to sit on the road with 100% contact... thats not me.... cause my inside is wearing like its not heaven.. if u know what i mean
but it might be the control arms...
if it is... would there be a difference with supra control arms compared to the SC 400 arms
not sure what the control arms aspect will help with performance wise
so start explaining if you can
peace
Ian
Old Jul 12, 2002 | 03:33 AM
London Bill's Avatar
London Bill
Wheel Alignment is often just the tracking (toe in/toe out), your suspension geometry is checking/resetting the camber, castor, KPI (included angle) and tracking for the front, the rear only has the camber and tracking adjustable.
If these are correctly set to factory specs (at the current ride height) then you should not get abnormal tyre wear.
Although the settings may be correct on the static geometry set-up, once the car is moving If you have worn suspension bushes this will allow the arms/hubs to shift under load and can present abnormal handling and tyre wear, I have just had all the front lower bushes replaced and the steering/handling has dramatically improved.
Old Jul 12, 2002 | 08:28 AM
pcmw's Avatar
pcmw
trudremz16,
I guess I can put it very simply.
If your tires are wearing abnormally, then get the car aligned. If the shop says ALL OKAY, then ask then about the tire wear.
If they say that they can't fix it then your cars suspension is bent or damaged because everyone else doesn't have this issue. If your lower arms are worn they will be able to see that and tell you.
MW
Old Jul 12, 2002 | 11:44 PM
1BomexLex's Avatar
1BomexLex
cool...ill have to get that checked out
thanks guys
Old Jul 13, 2002 | 12:14 PM
AUTOBOTxSOARER's Avatar
AUTOBOTxSOARER
My tires butterfly like crazy.... Im not sure if you can tell from the pic or not but here it is
Old Jul 13, 2002 | 12:16 PM
AutoCoutureSC
autobot, what 19 width did you get for front and rear? tire size?
i also remember you stating that you got your eibachs cut right? this will help in determing what the problem is
LexusK
Suspension and Brakes
Oct 21, 2016 08:48 AM
2jzcoupe
Sep 2, 2014 07:03 AM
murder
Jun 11, 2011 07:16 PM
djb5118
Jul 1, 2010 06:13 AM
RocketGuy3
24
Jun 13, 2010 01:14 PM
