Rwhp?
I thought the SC400 had about 200 on the original 92-94 1UZ, 210 on the 95-97 1UZ and 240 on the 98-00 due to the increase in power over the years. I heard the SC300 was in the 170's to high 180's though.
Excerpt from Intellexual net
Differences between the SC300 & SC400
The SC300 comes with a 3.0-liter 182 ci cast iron inline-6 motor with aluminum heads (engine designation: 2JZ-GE) and a choice between a Toyota A343E 4-speed automatic transmission with overdrive or a Toyota W58 5-speed manual transmission (available from 1992-1997).
From 1992-1997, the power was rated as 225 horsepower @ 6000 rpm and 210 ft/lb torque @ 4800 rpm. From 1998-2000, the power was rated as 225 horsepower @ 6000 rpm and 220 ft/lb torque @ 4000 rpm. Curb weight ranges from 3494 lbs. in 1992 to 3560 lbs. in 2000.
The SC400 comes with a 4.0-liter 242 ci cast aluminum V-8 motor with aluminum heads (engine designation: 1UZ-FE) and a standard equipped Toyota A343E 4-speed automatic transmission with overdrive (from 1992-1997). No manual transmission was ever offered for the SC400.
From 1992-1995, the power was rated as 250 horsepower @ 5600 rpm and 260 ft/lb torque @ 4400 rpm. From 1996-1997, the power was rated as 260 horsepower @ 5600 rpm and 270 ft/lb torque @ 4400 rpm. From 1998-2000, the power was rated as 290 horsepower @ 6000 rpm and 300 ft/lb torque @ 4000 rpm. Curb weight ranges from 3575 lbs. in 1992 to 3655 lbs. in 2000.
In general, you can figure a minimum of 15-20% drive train loss off of those numbers before it gets to the wheels, maybe more.
sunblinds
Apr 28, 2018 04:34 AM
jsyjordan
May 23, 2006 02:12 PM
