alt/batt problem
Old Jul 24, 2010 | 01:04 PM
OG_SC300's Avatar
OG_SC300
Default alt/batt problem
i havent been driving the car because i thought the altenator was bad. after 3 alts and the car still dying i decided to test all the alts(after 4 months)
2 are over charging(so i geuss the machine was off because they read the same) and 1 had a bad bearing. both batterys i have are now 100% useless.
the car would run for a few miles than drain the juice from somewhere. and after a jump for a few minutes the car would still be dead.
all i did was change the alt and the batt where could i have missed a ground or messed something up that is causing a short? or is there a fuse relay that i do not know about? im buying another batt tonight and going to try it and see what happens.
Old Jul 25, 2010 | 08:31 PM
topdog849's Avatar
topdog849
is your battery light flashing?
Old Jul 25, 2010 | 09:33 PM
shonuff53's Avatar
shonuff53
what do you mean by short? what is happening exactly or not happening? Not sure if you're buying those reman alternators from the local parts place but I myself replaced an alternator not long ago and under high revs/load my battery light comes on I've metered the system and everything seems ok for me and all I do is reset the car by turning it off and back on again but I'm guessing these reman alternators are junk my old beat up one was a soarer alternator which runs less amps and thats why I replaced mine but it seems to be crap however now at least my lights don't dim and electronics don't run crappy at idle.
Old Aug 4, 2010 | 03:36 AM
OG_SC300's Avatar
OG_SC300
problem solved i had the new batt old alt. than new alt with the drained battery. bought a new battery works perfect. never thought new batt new alt. thanks though
Old Oct 14, 2010 | 05:57 PM
2jzsoarerH's Avatar
2jzsoarerH
today my battery light started blinking while i was driving then disappear....i turn my lights off then turn it bak on...i start to hear static....btw i replace my battery couple months ago....the car does not have a problem starting but some times the cluster light would goo dim dim then bright again..this happens randomly ...then static....what could this be?
Old Oct 14, 2010 | 09:55 PM
Sup2jzgte's Avatar
Sup2jzgte
Just a month ago I had pretty much the same problem. I was driving out of the blue my battery light came on...........then after a few minutes shut off............a few minutes came back and it did this all day. When I would step on the brake or touch the window switches the battery light would turn on...........the battery light would even flash in the pattern as my turn signals when I was making a turn. if I turned the ac on the battery light shut off.
The battery is only a year and a half old, battery terminals are brand new and tight, I regrounded all the grounds and none of that worked....Put a new alternator in and the problems went away
Old Dec 4, 2010 | 09:36 AM
2jzsoarerH's Avatar
2jzsoarerH
im having the same problem but i have a 2jz ge jdm motor in my sc ....would the usdm alternator fit on the jdm motor
YoungNas
16
Dec 10, 2018 04:13 AM
jean1982
Sep 22, 2014 11:37 PM
jayntee
Oct 21, 2013 12:25 PM
OG_SC300
Apr 21, 2010 09:09 AM
topdog849
Aug 18, 2008 06:32 PM
