Accident :-( --- Shifter and Power Steering Issues
I need help guys.
I got into an accident on my way back home – my fault. The car was drivable and I got home just fine but the power steering starting getting tight and making a humming noise. I opened the hood and there was fluid in the power steering reservoir and all around it (looked like it was leaking!). Could this have been caused by the accident? Both cars only had bumper damage.
Second issue – my shifter won’t go into park and I can’t pull out the key. If I force the shifter into park, I can take out the key and it locks into place. However, when I put the key back in, the bottom is very hard to push and the shifter falls back into the reverse position (the gear light is still in park). The light doesn’t correspond with the shifter position.
Please help – have I gotten myself into a big mess mechanically?
thx --- poor start to the weekend
I need help guys.
But more importantly, if you hit hard enough to buckle the hood (bonnet ), and your engine and tranny mounts were already shot by age and mileage beforehand, then you may well have shifted the engine and transmission forward on it's mounts during the impact causing the tranny linkage to bind up where it passes through the tranny tunnel. This could explain the difficulty putting it into park.
so...finally got the car back today. Both the power steering pump and the rack-and-pinion were leaking. Got both changed for $700.
Still having trouble with the shifter not aligning up. In order to take the key out of the ignition, I have to physically push the shifter towards the front and remove the key. I was hoping it was something I could take a look at before going to the shop -- any suggestions?
thanks
thanks
user 528962307
10-19-13 05:05 PM
mfb496
09-03-12 05:11 AM
Dx3
SC- 1st Gen (1992-2000)
03-17-10 08:09 AM
