Clunking noise from right front end?
IIRC, the supra springs have a reduced coil diameter a the bottom vs. the top, whereas the SC coils are same diameter top and bottom. There was just a heated thread here ()relating to this very topic (it was actually about mixing sc and supra spring/shock combos IIRC) . It had pics which showed how where the coils are supposed to sit and explained how the get taller if they're not sitting correctly on the lower seat. Might wanna search around for it and verify your coils are where they should be if your height is so far off.
