service manual/wiring diagram
i need the wiring diagram for the memory seat buttons, cig lighter, and the cruise control. i searched but only found what some of the wiring's colors were.
none of the above mentioned work and i would like to see if i can handle this myself with the help of a manual. |
If none of the above work, try looking for something common between all of them. Such as a fuse is most likely the problem. If not grab out your DMM and start looking for power and ground's.
bump, i doubt it is a fuse for the cruise control b/c the CRUISE light comes on in the dash. unless there is a special sequence to activate it
It looks like your cigarette lighter and memory seat buttons share the same ground point. This grounding point can be found on left kick panel above the fuse box area. Check it out.
Sorry disregard my last post, I double checked and none of these functions have anything in common.
The grounding point for your memory seat buttons is actually underneath your ashtray. I would take your center console out and see if it is bolted down and while you are there, check to see if your cig. lighter is even plugged in from behind.
cig lighter works but it is temper-mental. i have to wiggle the plug to get my charger to stay lit. so it is most likely the barrel itself that is the issue. cruise control, mem seat and the switch for the seat itself are still my gremlins.
CRUISE light shows up on my dash but it does not keep the constant speed. is there a motor or switch that needs to be tested under the hood? the seat switch works in all directions EXCEPT when i want to lower the seat and the auto slide when you tilt the seat forward and backward does not work (both issues with d/s only) can anyone confirm that the switch itself is bad on the seat which is causing me to not be able to lower it |
The auto slide entry feature was engineered to only work for the passenger seat when reclined forwarded for rear passenger entry.
well thanks luxor, that solves that issue! lol
