SC- 1st Gen (1992-2000)
2JZGE Na-T TT Ecu Mod
Old 09-17-18, 06:13 PM
  #3676
Bdub215
Bdub215's Avatar
I think it's safe to say my days on the TT ECU are numbered. Jumped on the rollers and with a few changes over last year, I made 403/365 on 15 psi. Terrible AFR but no piggyback needed
191K mile GE
Unopened motor
Walbro 255
Oside tiger 440cc injectors
Stock IM/TB
Treadstone turbo manifold
S366 @ 14 & 15 psi for the dyno runs
JDM TT 6 speed ECU Freshly rebuilt
Southbend stage 3 clutch
Modified Tripod R154
8 degrees base timing
3.91 FD
10.3 AFR
aznexus (09-21-18)
Old 09-18-18, 09:22 AM
  #3677
Ali SC3
Ali SC3's Avatar
Looks pretty good, with an AFR of 10.3 raise the boost up until its in the mid 11's (like 11.5) and see what power it puts down, maybe like 17-18 psi.
You can use a boost cut controller to avoid boost cut and raise the boost, or you could also run 550cc injectors and a piggyback which raises boost cut also and give you some more headroom.
A standalone is not a bad idea much above that, but seems you could turn it up some as is and still be good. running 10.3 alot will probably start building carbon deposits etc..
Old 09-18-18, 09:01 PM
  #3678
Bdub215
Bdub215's Avatar
I've got a V1 ready to go in. And I just bought a daily. So I'm gonna refresh the motor and change a few things and proceed with tuning. I spent ages going through the old threads finding the proper settings for that thing. I actually think I've got a fairly decent base cal to start with. Might upload that here soon.
As much as I'd like to add the boost cut controller, boost cut has saved my *** quite a bit. Speed cut can kiss my ***. But I have found a way to cheat that so I'm good
Old 09-19-18, 07:58 AM
  #3679
99SC42
gte & na-t
99SC42's Avatar
Do not use a 12V to turn the pump ON, it will drain your battery if you turn the key ON for a certain amount of time.
Best way to do it , is using the stock trigger at the relay to trigger it.
Old 09-20-18, 04:31 PM
  #3680
scsexy
scsexy's Avatar
davv, might be an intake piping leak or something with the map sensor.
SC, it can be normal but a fuel filter might not be a bad idea if you don't know when it was done.
I would do the 12v relay triggered off the fuel ecu, the denso might be a bit much for the stock fuel ecu also.
What do you mean the denso might be a bit much for the stock fuel ecu?. the fuel pump wouldnt run until i did the 12v mod. I have a fuel filter sitting in my box i should do it lol i just didnt think it would be a cause because it only happens when hot. like over an hour working hot.
Old 09-25-18, 12:26 PM
  #3681
davvv
davvv's Avatar
Almost there! My iacv was leaking big time. Turns out I have the wrong one . The flange on my ffim is for 2jzge and I have no idea how to put a gte one on. Either way I blocked it off. Now two issues left. When I start the car it's automatically at 14.7. But once I move it's at 12.5 .No matter what at idle it's at 12.5. when I start moving it goes up to 14.7 and slowly goes down like it's supposed to. It goes down as boost comes on and stops at 10 flat . Right now I'm only at 10-12 lbs.. That's one issue. I still get cut when I go into boost. If I slowly go up into boost it's fine, runs smooth afr is where it's supposed to be and everything. But if I try to give more throttle it automatically cuts. You could kinda see in the beginning of the video below.
​​​​​Does my 90mm throttle body have anything to do with it? This week I'mma do boost leak test see if there's any leaks.
https://youtu.be/82JZJBDBKO8
Old 10-08-18, 12:39 PM
  #3682
suprasoup
suprasoup's Avatar
Just did this upgrade and I'm using the is300 coils with 660cc injectors and tuning with safc neo. I also have a 485lph walbro. However I cannot get the car started. I'm getting spark and gas. I'm getting way to much gas. I'll pull my plugs after a few test starts and they will be soaked with gas and black. Do I need to dial more gas out? I tried taking 35% out across the board and I do have it setup on pressure sensor 1in 1out. Am I missing something? I keep flooding the engine and then have to let everything dry before trying again.
Thanks for any help
Old 10-09-18, 04:08 PM
  #3683
Ali SC3
Ali SC3's Avatar
I think people are in the mid 20's correction with the 550's. I am not sure how much the correction will be with the with the 660s but you probably need to experiment.
going with the 550's might be another option depending on what you are looking to make. I don't remember the safc settings but just look up for the one with a pressure sensor.
Old 10-14-18, 01:01 AM
  #3684
suprasoup
suprasoup's Avatar
Thanks for responding Ali SC3. I grabbed some new 440cc injectors hoping it would fix the problem and yet the car is still getting to much gas. The things I have checked are the following-
is300 coils checked out and placed in correct order.
map sensor works and is getting 5v from ecu and outputing 2.5v with car off.
spark plugs and wires tested fine.
tested and adjusted tps per tsrm.
checked my wiring more times than i can count.
Any help is much appreciated.
tried 3 different igniters
checked all plugs for sensors
rebuilt ecu
rebuilt motor
12v mod 485 walbro works
the only thing i can really think it could be is the ecu. Any help would be very appreciated.
LEXXIUM (02-13-19)
Old 10-16-18, 09:55 PM
  #3685
Bdub215
Bdub215's Avatar
rebuilt ecu
rebuilt motor
You basically said what your issue was.
12v mod w/ an overkill walbro 485. You don't need such a big pump. I went from the stock pump to a 255 and my cold start AFR went from 12.6 to 11.6. Get a smaller pump cause that's too much.
Old 10-17-18, 06:53 AM
  #3686
gerrb
Super Moderator
gerrb's Avatar
The size of the pump (being big) even if it was on a 12v mod doesn't really matter. You can even use a huge Weldon -2345a pump as long as the fuel regulator maintains the fuel pressure needed by the injectors. Like, most injectors should have a base fuel pressure of 43.5psi and rising based on boost .
The amount of fuel squirted on the injectors depends on the size of injectors and how much time the injector coils are energized and are left open by the ECU on the assumption that we have the right fuel pressure that is regulated by the Fuel Pressure Regulator.
The ECU energizing the injectors (sending ground signal to the coil/solenoid to make the plunger rise so fuel can flow) depend on different factors though like information sent to the ECU by the different sensors.
LEXXIUM (02-13-19)
Old 10-17-18, 10:59 AM
  #3687
99SC42
gte & na-t
99SC42's Avatar
Thank you GerrB! Thats what alot of people dont know.
The stock ecu were built to run rich...Thats normal.
Now check your Return line, make sure its not pinch or retricted..because if you pinch the return line that will will raise you fuel pressure up.
Old 10-20-18, 09:25 PM
  #3688
LEXXIUM
LEXXIUM's Avatar
Ali, I need your help brother please!!!
so I’m in the middle of my wiring and since this is a 97, I have some questions.
plrase look at this pic and tell me what else I’m doing wrong.
so I got 3 wires coming from coils to the igniter for c 1 c2 and c3 all done, then I added 5 pins to the ecu, but those aren’t joined to the igniter yet, when looking at the diagram do I need to splice the b+ and run one wire to the coils B+ side and solder the old b+ wire to it and then splice it to the igniter?
this is a busy pic, I was looking a aswiley pics and build on his 97 his diagram helps me get the tac wire done, but wanted to know what to do with the old c- wire and this b+ that’s coming from the old tac to coils to igniter?
Thank you Ali!!
Old 10-23-18, 09:18 AM
  #3689
Ali SC3
Ali SC3's Avatar
Thank you Ali!!
What I usually do it take the b+ wire from the stock ignitor, and plug it right into the new ignitor plug as it uses the same type of pin.
Then a few inches back on that b+ wire, I cut back some of the insulation off all around with a loose blade and then wrap another wire around it and solder it, and that wire runs to the 3 coils.
Another option is to run a new switched 12v new power wire for the coils using a relay from like the fusebox or something, but that b+ wire seems to have enough juice for what we are doing.
the old coil is not used as its on the passenger side, and it has c- and b+ wires on that plug.
if you are unwrapping that side of your harness though, you could reuse the c- wire for one of the coils and even the b+ wire as those wires go over the middle of the engine to the passenger side and unrapped would reach into the spark plug area. I didn't unwrap that part of the stock harness till much later on when I went FFIM and was rerouting stuff, but it isn't that much stuff to unwrap if you want to get the b+ wire from there and not splice at the ignitor.
hope that clears some of it up. lots of ways to do it.
Old 10-25-18, 11:35 AM
  #3690
LEXXIUM
LEXXIUM's Avatar
Thank you brother for a clarification!!
The stock coil wire, I couldn’t even find where b+ was going in the ecu plug, but no biggie, I did find the ground wires for it pin 79 and 80 I think, the c- I tried to follow it to the ecu maybe it’s me, but couldn’t find it either, no big deal also. I wish I could post a pic of what I did, I just have wires and soldered it all
This thread should be a sticky
Thank you! Thank you! Thank you!
Quick Reply: 2JZGE Na-T TT Ecu Mod
