ok so i decided to switch subs in my lexus... i have all the bolts and panels off but when i try to pull the sub out it wont budge. wht do i need to do to get it out?
If you have the rear deck out you can see there are 4 bolts on the metal bracket around it that hold it to the car... It might be rusted/sealed some how but if those 4 bolts are undone it should come out so try to pry it. If anything else there are like 6 philips screws on the outer lip of the sub you can remove.
