Clutch Master Cylinder question???
Old Feb 28, 2010 | 04:58 PM
celiman05's Avatar
celiman05
Default Clutch Master Cylinder question???
i was wondering if anyone knew if there was a difference in oil delivery between the sc300 clutch master and the supra clutch master? im running an r154 in my sc and i wanna make sure the clutch is fully releasing.
Old Feb 28, 2010 | 09:27 PM
Gspec's Avatar
Gspec
JAck the rear end off the ground.......start the engine, depress the clutch and put it in gear....do the tires start to rotate? there's your answer.
Old Mar 1, 2010 | 02:27 PM
99SC42's Avatar
99SC42
Same part#
Old Mar 1, 2010 | 07:30 PM
celiman05's Avatar
celiman05
ok the reason i was wondering was because i just smoked my $650 clutch and burnt the hell out of my $350 flywheel for no apparent reason. the clutch was only one season old. and that sucks. it shifted a touch hard even after the complete rebuild i did on the tranny. is there any adjustment on the clutch pedal?
Old Mar 1, 2010 | 09:10 PM
Cleanshots's Avatar
Cleanshots
id say re-bleed the clutch line to get all the air out just in case.
Biggu
Aug 7, 2008 05:36 PM
pnyboy27
Aug 4, 2008 01:57 AM
minnyminh
Feb 13, 2008 10:53 AM
LCSC
Oct 30, 2007 11:44 AM
MR-2 Turbo
May 17, 2005 08:13 PM
