ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   Leak on passenger's side floor (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/484597-leak-on-passengers-side-floor.html)
User 11220 Feb 26, 2010 06:12 PM
delete
delete delete
turbodremz Feb 26, 2010 09:08 PM
heater core
mitsuguy Feb 27, 2010 07:14 AM
could also be the a/c evaporator core not draining properly... if its water = a/c, coolant = heater core
User 11220 Feb 27, 2010 09:23 AM
delete delete
1JZPWRD Feb 27, 2010 10:53 AM
The sunroof drain maybe clogged up, I believe there is four hoses, or one on each corner to drain properly. Check that.. Blow some compressed air down each of them and see if you see any water that way, if you have the carpet still out of it.
User 11220 Feb 27, 2010 12:28 PM
delete delete
$C300 Feb 27, 2010 01:19 PM
drop the headliner, i had a similar issue. after you drop the headliner youll see the four sunroof drains, just clean um out.
Elitesrule Feb 27, 2010 01:22 PM
What if you have the same problem but don't have a sunroof?
$C300 Feb 27, 2010 01:38 PM
sometimes the cowl gets gets clogges, the area under the windshield on the out side by the wipers, there is drains under there that can get clogged.
Elitesrule Feb 27, 2010 02:31 PM
So clean out around the wipers on the passenger side and it will be fixed? No need to drop the headliner?
User 11220 Feb 27, 2010 02:53 PM
delete delete
1JZPWRD Feb 27, 2010 04:19 PM
I cant believe I actually posted something right on here. :-) I am glad you possibly found the problem.
BigWaveSC Feb 27, 2010 04:33 PM
is it raining outside when it happens?
the little rubber plugs on the floor board might be missing.
that made little pools of water in my car before.
User 11220 Feb 27, 2010 06:19 PM
delete delete
1JZPWRD Feb 28, 2010 10:53 AM
Glad we could help you out and you found the problem.
