(battery)Starting issues HELP !!!
Ok guys, I have a sc300 with a 1jz. As soon as i get my car to run after a month the battery dies. so i go to replace it with my friends battery not thinking about the size of the terminals. i go ahead and plug it in in the negative side and then i tried putting it on the positive side but the terminal was too small on the battery and sparks flew from the battery. i immediatly disconnect and plug in a new right battery. Now the car wouldnt start and all you hear is the fuel pump priming. so i checked the fuses in the engine bay and a 20 amp blew and a 120a alternator amp blew, so i go ahead and change it out and still that didnt help. you can't even hear the starter click now when before you did. Any suggestions?????????????
ya i checked every single fuse in the engine bay and inside the drivers side, unless theres a 3rd fuse box im unaware of. Do any of you think i fried a wire to the starter?????????
acenase
Performance & Maintenance
02-12-24 06:35 AM
