will these spark plug fit the SC3?
i've been doing some research on what spark plugs to use when someone goes turbo and found the DENSO Iridium Power Spark Plug IK27..my questions are, will these exact ones here on the link fit since it doesn't say what car it'll fit on it or do they fit any car?
http://cgi.ebay.com/ebaymotors/6-DEN...#ht_3794wt_939
I have mine gapped at .28, for the ik27's not sure..that one you might want to check on clubna-t..
whats your compression going to be at, and what size injectors are you planning on using?
running Marks/XS power 1.3mm hg kit and PTE 525cc injectors..
Plug selection
Note - This selection list does not take Nitrous into account. If you have Nitrous go one grade colder than this table advises at your boost/performance level.
Normally Aspirated
NGK - Standard - BKR5ES-11 (2382) - gap 1.1mm
NGK - V-Power - BKR5EYA-11 (2526) - gap 1.1mm
NGK - G-Power Platinum - BKR5EGP (7090) - gap 1.1mm
NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm
NGK -OE Laser Iridium - IFR5T11 (4996) - gap 1.1mm
NGK - Iridium IX - BKR5EIX-11 (5464) - gap 1.1mm
Denso Platinum - PK16R11 - gap 1.1mm
Stock TT
NGK - BCPR6EP-11 - gap to 1.1mm PLATINUM
NGK - BKR6E (2756) - gap 1.1mm
NGK Iridium - BKR6EIX-11 (3764) leave gap alone
Denso Platinum - PK20R11 - gap 1.1mm
Denso Iridium - IK20 - leave gap alone
TT @ upto 1bar
NGK - BCPR7ES (3330) - gap 0.9mm
NGK - BKR7E (6097) - gap 0.9mm
NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone
Denso Platinum - PK20R11 - gap 0.8mm
Denso Iridium - IK22 - leave gap alone
TT/hybrids @ upto 1.3bar
NGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK24 - leave gap alone
Single Turbo/Big Twins @ upto 1.3bar
Single Turbo/Big Twins @ upto 1.8bar
NGK - BCPR8ES - gap 0.6-0.7mm
NGK - BKR8E - gap 0.6-0.7mm
Denso Iridium - IK27 - leave gap alone
Single Turbo/Big Twins @ 2+bar
NGK - BCPR8ES - gap 0.6mm ??? UNTESTED
NGK - BKR8E - gap 0.6mm ??? UNTESTED
NGK Iridium - BKR8EIX or BKR9EIX? - leave gap alone ??? UNTESTED
Denso Iridium - IK27 to IK31 - leave gap alone ??? UNTESTED
Information sources
Denso
NGK
Sparkplugs.co.uk
Personal experience
Previous discussions on this and other BBS's.
Plug selection
Normally Aspirated
Stock TT
TT @ upto 1bar
Information sources
Denso
NGK
Sparkplugs.co.uk
Personal experience
judging by the specs above, and confirming that it is a hotter plug, I would say .030 would be the minimum. I think if you went with a .028 (i put .28 above-fail) they may foul quickly.
nezlyfe
Nov 21, 2017 10:19 AM
Scott1258
Dec 31, 2006 04:00 PM
