problem power steering fluid bubble????
Old Dec 14, 2009 | 05:43 PM
ShiftyD2k's Avatar
ShiftyD2k
Exclamation problem power steering fluid bubble????
i got ps fluid with bubble and really bad noise when steering move.. what ps fluid color suppose to ?? so i have to flush and put new fluid? help me pls.
Old Dec 15, 2009 | 07:01 PM
topdog849's Avatar
topdog849
i know on my sc3 it uses automatic transmission fluid dextron 5. i flushed mine with synthetic. jack up the front of the car with it running and turn the wheel fully left and right to get the bubbles to float to the top. your solenoid screen going to your rack may be clogged(search) or your o-ring on the bottom of the resevour could be leaking.
Old Dec 22, 2009 | 08:12 AM
millertime's Avatar
millertime
I flushed mine with dextron 3 ATF because i had the same problem,
seems like everytime it gets cold out my car wistles and the ps fluid turns to slushy.
so i flushed it and it should be good till next year
Old Dec 23, 2009 | 03:43 PM
66fasty's Avatar
66fasty
I'm having the same problem.I replaced the pressure line and rubber return lines, it was good for a day then back to overflowing and the fluid looks all frothy. It means air is getting in somewhere.
bob2200
RX - 1st Gen (1999-2003)
Feb 10, 2014 08:10 PM
omeo
IS - 1st Gen (2001-2005)
Jan 14, 2014 05:07 AM
carguy07
Apr 26, 2010 04:26 PM
Luke_in_SD
May 21, 2008 07:49 PM
