replacing rod bearings, motor in car?
Old Nov 9, 2009 | 09:47 AM
T4-Teg's Avatar
T4-Teg
Default replacing rod bearings, motor in car?
I have a 1992 SC300 that I plan to replace the rod bearings in. My question is can you reach all 6 rods just by taking the lower oil pan off? I understand if you remove the upper oil pan, the motor must be removed from the car. Im really not wanting to pull the motor, just for a 1 hour rod bearing job lol.
If anyone has replaced the rod bearings, with the motor in or out please chime in.
Thanks!!
Mike
Old Nov 9, 2009 | 12:49 PM
t66sc3's Avatar
t66sc3
You can drop the front subframe and hold the engine up with a hoist but other than that its not to fesiable to get the upper pan off with the engine in the car.
Old Nov 9, 2009 | 01:16 PM
T4-Teg's Avatar
T4-Teg
^ So are you saying the upper pan must come off to reach the rod bearings?
Old Nov 9, 2009 | 05:36 PM
audi2nr's Avatar
audi2nr
upper pan needs to come off to reach all rods. why are you replacing the bearings?
Old Nov 9, 2009 | 08:05 PM
T4-Teg's Avatar
T4-Teg
Well I was hoping for a quick fix to the rod knock so the car would be drivable for a little while.. I guess ill pull the motor and build it now.
Old Nov 9, 2009 | 10:05 PM
2jzlex's Avatar
2jzlex
In the time it would take you to do it underneath the car you could pull the motor have it fully rebuilt and dropped back in.
Old Nov 9, 2009 | 10:42 PM
vangb2's Avatar
vangb2
If it already knocked, it may be too late. You may have to get your crank or rod reground if the clearance is too much and use oversize bearings. If it's true, you need to pull the engine out. Get the clearance spec from the dealer. Buy some plastic gauge from the autostore. Measure and compare spec clearance.
Other problems that you may run into are the bolt breaking because it's brittle or the holes will strip when you remove the bolts. If this happens, it may be tough to helicoil underneath the car.
Old Nov 10, 2009 | 05:39 AM
T4-Teg's Avatar
T4-Teg
I know all this.. I was just hoping for a easy badaid fix until my motor from japan comes in
Im about 99% sure the rod/crank suffered damage. Oh well... Ill start pulling the motor
thanks fellas.
ashtray
Mar 15, 2013 09:34 PM
97JZA80
Apr 23, 2012 05:11 AM
motorheaddown
Jul 29, 2009 08:06 PM
Carfreak70
SC400 / 300 Classifieds
Oct 26, 2008 08:28 PM
