Odd Battery Problem
Old Nov 5, 2009 | 06:17 PM
nfordhk's Avatar
nfordhk
Default Odd Battery Problem
Alright so I put a new battery in my car maybe 3-4 months ago. Everything has always been fine starts right up.
Today I drive to school. Then I drive to my 2nd school. Drive home. And I get ready to go to tacobell with a friend and dead? I get all the dash lights at first like it was going to work I try to turn it over and nothing. Then I get no dash lights.
I tried jumping it didn't even need to start the other car and it worked great let it sit for 10-15 then drove it for 5. Brought it home turned it off tried to turn it back on and same thing dash lights at first then totally nothing.
Then I have this battery charger thing that doesn't require another car and it started right up it has a battery level reader and it read good. But if I turn it off it won't turn back on. What could be this problem?
Old Nov 5, 2009 | 06:20 PM
3000's Avatar
3000
It might be a ground problem. Check all the ground wires. Or your alternator is dead?
Old Nov 5, 2009 | 06:23 PM
nfordhk's Avatar
nfordhk
My terminals are good what other ground wires do you speak of? Iv thought of that im going to get it tested tomorrow.
Old Nov 5, 2009 | 06:24 PM
3000's Avatar
3000
Not just the terminals. All the other ground wires around the engine.
Old Nov 5, 2009 | 06:42 PM
nfordhk's Avatar
nfordhk
Guess Ill double check those tomorrow. Ty
Old Nov 5, 2009 | 07:01 PM
dwebb99's Avatar
dwebb99
check your battery grounds. You may have corroded ground wires and/or positive wires. Check your starter and it's connections. Check your coil for spark. Have Autozone do a free check of your battery and alternator. Do a search, tons of info out there on what/how to check. good luck
Old Feb 3, 2010 | 04:24 PM
Amini9's Avatar
Amini9
CL Folding 200,000
bump, i have a very similar problem.
has anyone else had this similar problem and fixed it or can someone direct me to a fix-it thread?
Old Feb 4, 2010 | 05:13 AM
Johnny3's Avatar
Johnny3
You gotta get the battery tested First. Probably bad, if not you can move on with other checks.
intempo
Oct 5, 2017 05:48 AM
Wilbick
RX - 1st Gen (1999-2003)
Oct 27, 2015 08:15 PM
xaper
15
Jun 17, 2014 01:42 AM
dave95sc
Jun 23, 2004 08:56 AM
landolakes
Jul 5, 2003 05:03 PM
