extended wheels studs????
Old Oct 1, 2009 | 10:01 AM
jeflex300's Avatar
jeflex300
Default extended wheels studs????
i have 1992 tt sc300 with work euroline le's, sitting on a plus 32 offset....
ive looked everywhere and i can not find extended wheel studs
i know the stock ones are 40mm but i need 50-55mm, does anyone know where i can find them??
Old Oct 1, 2009 | 10:10 AM
masagsxr's Avatar
masagsxr
go online, ebay, local wheel stores. They should have or can order those for you.
Old Oct 1, 2009 | 10:12 AM
chrispy's Avatar
chrispy
Ichiba makes some. They also make spacers too if you need them.
Old Oct 1, 2009 | 10:23 AM
jeflex300's Avatar
jeflex300
awesome.....i was a little nervous drivin on 4 threads
Old Oct 1, 2009 | 11:45 AM
Biggu's Avatar
Biggu
get a set of ARP for a IS300 and you will be set. thats what i did.
Old Oct 1, 2009 | 01:33 PM
1KhpWrx's Avatar
1KhpWrx
I've heard nothing but good things about the arp wheels studs
Old Oct 1, 2009 | 01:38 PM
HellFish's Avatar
HellFish
ARP # 100-7715
lookin at about 40 bucks a corner.
Old Oct 1, 2009 | 02:28 PM
GZZ-TT's Avatar
GZZ-TT
Thats what I had all around: ARP IS300 wheel studs
Old Oct 1, 2009 | 03:04 PM
Myblacksc's Avatar
Myblacksc
Ichiba goes for about $2.00 - $2.50 each. They do make a 50mm, but not sure about 55mm.
You can run their bolt on spacers that has the studs on them that way when you change it up you won't have to run lug nuts for extended studs. They make up to 50mm spacer so I'm sure you'll have no problem finding the one you need. GL!
Old Oct 2, 2009 | 12:52 PM
drft_n_sc's Avatar
drft_n_sc
i have the ichiba 50mm in the front of my sc ... get with nigel here on the forums and he can them for you, i think i paid $50 for all 20 shipped
Old Oct 2, 2009 | 03:40 PM
camberSC's Avatar
camberSC
Are you putting spacers on?? What does your wheel offset have to do with extended studs? lol
Old Oct 2, 2009 | 04:31 PM
LEX_MAN's Avatar
LEX_MAN
I think its better to get the extended studs rather than getting the adapters with already built in lug bolts. You can always run a smaller spacer if you decide to change the wheels.
Old Oct 2, 2009 | 08:21 PM
LexAnt's Avatar
LexAnt
size difference between OEM and the ARP studs
is150
Feb 27, 2013 09:07 AM
Rock-a-Lex
Suspension and Brakes
Jun 15, 2011 07:31 AM
bio3m
May 10, 2011 10:56 PM
Navigatn
Wheels, Tires & Brakes Forum
Jan 18, 2011 01:49 PM
Famou$LS
Nov 2, 2009 04:43 AM
