ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   need help with new 20's (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/429244-need-help-with-new-20s.html)
UR2klose May 17, 2009 06:54 AM
the rims i have are 20x8.5 255/35 front and 20x10 285/30 in back. the front is fine but im having a problem with the back. they rub a lot. i bamed in the little lip inside the fenders and they still were rubbing so i raise the back of the car about 3-4 inches now they dont rub but i hate how high it sits. ive seen plenty of sc's lowered on 20's so i know its possible. any idea on how i can just get back to stock height without rubbing? will stretched tires do it? if so what size do i need?
http://i45.photobucket.com/albums/f5...1638097313.jpg
Black Fire May 17, 2009 07:07 AM
10" wide tires are a big prob. If you put 9.5 rubbers that are 1" tall and drive SLOWLY over pot holes, u might make it. That just a big @ss wheel bro.
jubay May 17, 2009 08:02 AM
I had the same problem I switch to 275/30's in the rear and now no rub
RedPhoenix May 17, 2009 08:05 AM
offset on wheels?
Mr. Klean May 17, 2009 08:19 AM
Dude, i've seen ppl with 12" wides in the back. 10" isn't a big deal. Holla@ Wicked_SC or LRD or TeeLex. All of them are running 11" or more in the back. IMO, your rear tires are way too big for 10"ers. stretch it, that should work. And trim the inside lip a little. I'm running 275 30's out back and i have minimal rub over REALLY bad pot holes. AND, i haven't trimmed the lip at all.
Avarec May 17, 2009 09:35 AM
Ask any hood figah, theyd fit anything
UR2klose May 17, 2009 09:55 AM
Originally Posted by RedPhoenix (Post 4529029)
offset on wheels?
i dont know what the offset is for them.
ScottURnot May 17, 2009 10:11 AM
Off set would help, I know the tires and rim width will work but not with a small offset. I would say you would need a 45mm offset and a fender roll to pull it off. I run a 20x10 and a 35mm offset. I am going to try and stuff some 285/25/20's on them but from what I measure it may not quite fit.
Black Fire May 17, 2009 04:20 PM
LOL 2 true! +1 :D
GS FONZy May 17, 2009 04:45 PM
Start with step 1, if that's still not enough to clear, continue to step 2 and so on.
1. Shave fenders
2. Roll/pull fender
3. Stretch tires
4. Add negative camber
5. get aftermarket/custom arm for more neg camber as needed
6. wide body
LMAOMAO May 18, 2009 01:00 AM
If you go larger than 9.5 in the back you are going to have to do modifications to fit it without rubbing.
As stated before, you are probably going to need to pull the fenders and stretch the tires a little more to make it work.
lexforlife May 18, 2009 04:15 AM
i have 20 x11 and 305/25/20 tire and dropped on coilovers to where it sits right at the tire level or maybe 1/4 in tucked and no rubs
offset/pad height is the key
yes i trimmed off all but maybe 1/8 in of the lip but i clear easily
heres a pic and i have since lowered it about 1/2 in more :D
http://i35.photobucket.com/albums/d1.../DSC032031.jpg
joeazy187 May 18, 2009 06:17 AM
I went with 8.5 with 245/35/20 on the front and 9.5 with 275/30/20 on the rears. And I was able to drop ln some Ksport coilovers, no rub.
hyjaxx May 18, 2009 06:49 AM
1. Shave fenders
2. Roll/pull fender
3. Stretch tires
6. wide body
I'm right there with him on rolling the fenders and then adding neg camber.
SpiderN9NE May 18, 2009 01:04 PM
llllllllllllllllllll
i ran 275 30 on a 20x10 and stock it wasnt bad unless i filled the tank. i removed the trim and it was better. tein basic all the way down i had to shave the fenders. the i added 15mm spacers to 42mm offset and running a 245 35 on it and some negative camber and its looking pretty good.
