Interior trunk release
Old May 1, 2009 | 03:01 PM
986ci's's Avatar
986ci's
Default Interior trunk release
OK just go this thing a few weeks ago(1992 SC300) and while I become a little mod freindly with I have a annoying problem and thought I'd seek advise here 1st. My interior trunk release won't work at all, the gas door release works fine and I remember the trunk release worked likethe 1st day just never has worked since. Any ideas, fuse's, relay or is it simply cable driven?
Old May 1, 2009 | 03:26 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Its electric, if I can remember I think it has a key lock next to it? If it is pushed in the trunk won't release. Unlock it with the master key and then the switch should work saying it is that style. If the elcetric portion doesn't work check to see if your getting power to it when pulling the switch. Use a voltmeter to help you out.
Old May 1, 2009 | 03:40 PM
986ci's's Avatar
986ci's
yea I already checked to make sure the key didn't de-activate it, now guess I will check fuse able links and the fuse panel.
Old May 1, 2009 | 03:47 PM
gephross10's Avatar
gephross10
HAD THE SAME PROBLEM!!!! try the valet lock. you feel kind of stupid when you turn your key in there and then the trunk release works lol
SH212
Sep 27, 2024 05:28 AM
jmsmiff
Oct 14, 2013 06:53 PM
WJSC300
Oct 14, 2013 11:55 AM
scweetrob
Dec 9, 2011 05:00 PM
