g35 18" wheels fit sc300 with ls400 bbk?
I got a SC300 with ls400 BBK and want to know if a set of g35 18" stockers will fit. gettin tired of the polished tt wheels. anyone know?
I'm sure it will clear the calipers because I've got a friend who has the Rotora BBK on his SC and he uses the G35 rim as his spare tire and it clears the Rotoras.
They should clear unless infiniti made 2 different offsets, 1 for their regular brakes and 1 for the brembos.
check the sizes with what people have done in the Wheel and Tire sticky at the top of the page.
i believe the do have different offsets i know mine are 30 i believe
The 18s are all 18x8 +30 with staggared tire sizes 225/45 & 245/45
The 19s are 19x8 +30 and 19x8.5 +35 with 225/40 and 245/40 |
Should fit fine, the G35 with Brembos was only offered with the 18s, so I would assume they'll clear LS brakes as well.
should be just fine...no problem
ALL the G35 wheels clear LS/TT brakes
the 17's, 18's and 19's |
Do the G35 wheels fit well enough that you don't have to roll the fenders or have that crazy toe to tip them in? I've been looking at get a set of used wheels and came across a set of Works "19, 5x114.3, 19x10R + 48 O-DISK
19x8.5F+ 40 R-DISK (Big caliper) and I keep getting mixed reviews if they will fit well. Some say they will fit fine but other say they fit but will have the same sunk in look as the stockers without spacers. I really don't want to use spacers if I don't have to so can anyone confirm if these Work wheels will fit well and look good? They came off a GS if that's any help... Thanks, joe |
