Please help.
Old Nov 9, 2008 | 10:26 AM
sc400nitro's Avatar
sc400nitro
Default Please help.
Ok last night at the shootout I had a 200 shot in, and I guess I timed it wrong, and i had a horrible nitrous backfire, and it shot a big flame through the entire intake, I did a makeshift repair on it, and it was running horrible, and was running a second and a half slower than it did before the explosion.
It's either the MAF or something else, please help.
can I run without MAF?
Old Nov 9, 2008 | 12:18 PM
1985zcar's Avatar
1985zcar
Uhm, pretty sure your car needs a MAF to run, lol if you shot fire out through your intake, then yes, your MAF is probably ****ed, and you'll need to replace it.
Old Nov 9, 2008 | 12:50 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Yes you definitly need to run with a MAF sensorr cause the car will not run. You might have burned the sensors to the point were it does not funtion correctly. The IACV could also have been damaged other then the MAF. Make sure that you didn't blow any vacuum hoses off of the intake causing a vaccum leak. Running into more problems with that nitrous then you can deal with. Go to forced induction unless you just want to blow your car up on spray which like it seems it is going in that direction.
Old Nov 9, 2008 | 03:40 PM
sc400nitro's Avatar
sc400nitro
forced induction just does not do like nitrous like i run faster times than all these other sc400s with tt or a sc
Old Nov 9, 2008 | 04:16 PM
IS_250's Avatar
IS_250
can you post the dyno sheet and another video of one of your passes?
Im not doubting your claims, but with the last stunt you pulled I question your credibility.
xJimy23x
Jan 8, 2017 05:08 PM
jnaka006
Sep 4, 2011 10:38 PM
ISF-88
IS F (2008-2014)
Aug 17, 2010 06:36 AM
klepto2
Feb 11, 2010 09:45 PM
BlakSC
Sep 15, 2007 06:48 PM
