Emblems
Old Feb 21, 2002 | 10:19 AM
mjames08's Avatar
mjames08
Default Emblems
How do you change the emblems on an SC? Are they glued on?
Old Feb 21, 2002 | 11:32 AM
YuuDawg's Avatar
YuuDawg
glued on with rivets, just take some floss and pry it off gently, mine all came off very easily
Old Feb 21, 2002 | 01:03 PM
Keith13b's Avatar
Keith13b
They aren't glued on per se'. They have guide pins to fit into holes, and have an adhesive backing. Take an old credit card or a bondo putty knife and just slowly rock it back and forth under the emblem. You will feel it when you hit a pin, so just work around it. Once you get one emblem off, the others will seem so easy.
Heat gun is helpful but in no way required.
Keith
Old Feb 21, 2002 | 01:45 PM
anthracitetarga's Avatar
anthracitetarga
do a search. There have been numerous posts about removing emblems, but in short: heat the emblem up w/ a hair dryer, and then slide some dental floss behind it once the glue has gotten hot enough. Then after u have removed the emblem, get some sticker removal (that is safe on paint) and put on there to get rid of any of the sticky tape left.
Old Feb 21, 2002 | 07:47 PM
Jmai22's Avatar
Jmai22
anyone wanna sell me there word "lexus" mine got jacked. i have a first generation GS.
Old Feb 22, 2002 | 04:38 AM
Keith13b's Avatar
Keith13b
Are your emblems gold or silver?
I bought a new "Lexus" emblem in gold after someone tried to jack mine. The new gold didn't exactly match my 10 year old faded gold, so I have yet to put it on, and have since repaired the broken one. Let me know of your interested in a gold one.
Old Feb 22, 2002 | 10:55 AM
Jmai22's Avatar
Jmai22
i have silver emblems sorry but thanks
Old Feb 22, 2002 | 11:30 PM
Fantius's Avatar
Fantius
Mine have no adheasive left on them for some reason (I guess they were removed by previous owner or something). They slide on and off quite easily. What should I use to re-stick em, so they don't fall off or get jacked too easily?
Old Feb 23, 2002 | 03:55 AM
lex400sc's Avatar
lex400sc
Well there's hide glues (animal glue), polyurethane glues (plastic glue), and epoxy glues (composite glue). For a metal to metal bond that is highly durable, there is no solution other than epoxy resins (thinking about it, it's probably more of a plastic to plastic bond). Epoxy does involve a messy mixing and curing process, but is extremely strong and highly resistant to heat and moisture variations. Use a small amount of epoxy in the guiding pins and some on the backing of the emblem. Curing is only a couple of minutes and the bond will be very strong depending on what kind of epoxy you use. Other glue types may hold well at first, but it won't be long before nature breaks them down (in the summer the trunk of your car can reach 300 degrees farenheit, how well do plastics fare under those conditions?).
Old Feb 25, 2002 | 04:32 AM
Keith13b's Avatar
Keith13b
I'd use double sided automotive tape - used to hold on bumper pannels and emblems from the factory. Available at most automotive stores - 3-6$ a roll.
I wouldn't glue an emblem on - what happens when you need to buff the car or have some paint work done? The double sided tape holds strong.
Keith
Old Feb 25, 2002 | 04:56 AM
justinlarsen's Avatar
justinlarsen
what have people used to fill the holes?
Old Feb 25, 2002 | 09:18 PM
mjames08's Avatar
mjames08
I just got my emblems today.. does anyone want to see pics of the install or should I not waste my time... it sounds really simple
Old Feb 26, 2002 | 02:27 AM
lex400sc's Avatar
lex400sc
Go for it! It never hurts to post pics. Pics are fun.
May be an easy install, but visual aids will make it exponentially easier for others when it's their turn.
hoosier58
Sep 18, 2013 05:39 PM
lilcop17
IS F (2008-2014)
13
Oct 4, 2012 02:05 PM
javila32
Jun 2, 2009 04:32 PM
kylesc400
Nov 3, 2002 05:05 PM
