ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   Airbag light won't turn off (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/388383-airbag-light-wont-turn-off.html)
1985zcar Oct 28, 2008 10:37 PM
This is weird...has anyone ever had this happen to them? I wasn't having this problem before I swapped my 1J in, and now that it's done, my airbag light will not turn off, ever...like you take the key out of the ignition, lock the car, and it STILL stays on...anyone have an idea of why my car's doing this? lol
vinh Oct 28, 2008 10:39 PM
did you every start your car without your cluster connected?
O. L. T. Oct 28, 2008 10:41 PM
Doesn't matter it would cut off with the ignition off.
OneJay Oct 28, 2008 10:48 PM
Mine was on until I clipped that black wire I told you about, then it went away.
romeo291 Oct 29, 2008 06:03 AM
Oh hey, could you tell me which black wire you're talking about? Mine's stays on now, I just finished my 1jz-gte swap, and I know it's a common problem.
Biggu Oct 29, 2008 06:17 AM
just pull the light bulb...... no need to cut a wire.
craaaazzy Oct 29, 2008 06:47 AM
is that why mine i on??? man, what a pain, i guess i'll just remove the bulb as well. i'm assuming this light will not affect airbag deployment though...
craaaazzy Oct 29, 2008 08:31 AM
Originally Posted by nobleblack (Post 3961308)
I think he was saying to do this, I'm not sure if he said he did this. Disconnect your battery before you do this. The light is a common issue when you switch out the cluster. Also when you take the bulb out check the other lights around it to see if they still work, I want to confirm a theory of mine lol. If you go to lextech lighting there's a few solutions to this, if the reason it happened was because of a cluster exchange.
i sent mine to lextech but had to move the car w/o the cluster so i'm thinking that may have been it. need to go through that website and see what solutions you are talking about.
1985zcar Oct 29, 2008 10:15 AM
Yeah but like O.L.T. said, if you removed the cluster, it would cause the light to turn on, but it would turn off when you remove the key from the ignition.
I already clipped that black wire and it's still staying on, guess I'll have to pull the bulb out, weak. haha
OneJay Oct 29, 2008 10:52 AM
Its pin number 10 on the big white body plug.
