major problem removing y intake sc300
Old Aug 26, 2008 | 07:10 PM
93sc3005sp's Avatar
93sc3005sp
Default major problem removing y intake sc300
i started to do my vcg's today and have the tb removed and all the y intake bolts except for the 2 underneath that hold the metal vaccum lines, what a stupid design btw, anyway i tried to take them off with a 10mm box end wrench but one of them stripped and i have not touched the other one, so i removed the two bolts on the big vaccum ball, but that thing will not budge,i figured if i removed that i could at least get the intake off as to where i could remove the bottom bolts, i am stuck now and need help thanks in advance
Old Aug 27, 2008 | 05:41 AM
cbrasian's Avatar
cbrasian
well if you had the right tool for the right job you wouldn't of striped it... easiest way to remove those would be a deep socket with a wobble / swivel... have no fear though go to your local tool store snap on mac tool etc and ask for a reverse socket and that will save you costs for a good one around 40-60 depending on vendor but it will save your *** in case you do that again... and btw its a good design cuz it keeps it sealed an secure and also scare the people who shouldn't be touching a car in the first place from touching it
Old Aug 27, 2008 | 12:27 PM
93sc3005sp's Avatar
93sc3005sp
thanks man
Old Aug 28, 2008 | 04:47 PM
SCjzz's Avatar
SCjzz
or you could take a chisel to the side of the bolt and hit it with a hammer. thts wat my dad does when bolts strip. hit it so that it moves the way the bolt comes off.
Old Aug 29, 2008 | 01:03 AM
Blk97SC300's Avatar
Blk97SC300
use a 6point 12mm socket (assuming you used a 12pt to start off with).
OR, hammer in a 11mm socket
Old Aug 29, 2008 | 02:47 AM
cbrasian's Avatar
cbrasian
well since he's saying he tried to use a box wrench he prolly rounded it pretty bad.....also a punch or as come people call it a chisel won't exactly fit under there since the bolts are a pain to get to with one ,if its still stuck and your in oc area i'll lend a hand if needed... but get a reverse set anyways and don't buy the cheapy ones either cuz they just suck....
Old Aug 29, 2008 | 03:59 PM
93sc3005sp's Avatar
93sc3005sp
well looks like i will have have to buy a reverse set can somebody explain how they actually work? and where is the best place to find a set cause i called pepboys and they said they had no idea what i was talking about btw im in culver city
Old Aug 30, 2008 | 08:47 AM
cbrasian's Avatar
cbrasian
here ya go btw pep boys won't have it gotta go to a actual tool shop hers a link for a visual on what it is http://hand-tools.hardwarestore.com/...et-104723.aspx it is used to extract bolts by cutting into it....its really hard to explain without showing so theres a image... so so you get an idea oh and i'm in irvine lots of mechanics call it a reverse so maybe thats why they don't know what I was talking about I bought mine at snap on was a bit expensive but they came through to save my *** so many times it paid themselves off
Old Aug 30, 2008 | 12:44 PM
Sup2jzgte's Avatar
Sup2jzgte
Hey man I'm at work right now, so I cant post in detail but I did the exact samething. When I get out I can post exactly how to fix what you need with part numbers prices, etc........
That is if you have not figured it out yet
Old Aug 30, 2008 | 01:54 PM
cbrasian's Avatar
cbrasian
hmm how to fix stripped nuts replace them.......with new ones... prices 1.50 tops..... lol all he gotta do is extract the bolt with a reverse and go to hilco fastners and replace the nuts
Old Aug 30, 2008 | 09:59 PM
93sc3005sp's Avatar
93sc3005sp
well i got everything off, what i did was remove the part of the intake that the y connects to so that i could wiggle it around, then i got a 10mm socket that fit perfect even though one of my bolts was rounded, im going to post some pics of underneath my valve covers, i was amazed how clean it is in their, its like brand new, wish i could say the same for my intake and tb, its absolutely filthy in their
IISevv
Performance
Nov 26, 2018 07:18 AM
IISevv
Jun 22, 2018 03:15 AM
is25019
Mar 22, 2015 01:15 PM
efrayz
Jun 27, 2011 01:59 PM
