LS400 caliper bolt Part Number
Old Jul 23, 2008 | 11:28 AM
evileagle's Avatar
evileagle
Default LS400 caliper bolt Part Number
Ive been searching and I could'nt come across the part number for the shorter LS caliper bolts required for the install. Anyone know what it is? Im looking to do the install soon but I dont want to use spacers nor do I want to cut the stock bolts.
thanks!
Old Jul 23, 2008 | 12:42 PM
evileagle's Avatar
evileagle
actually guys, I found it...
its 9008010298. Toyots dealerships also carry the part but cost ~3x as much!
Old Jul 23, 2008 | 01:37 PM
JesLet's Avatar
JesLet
You can also call Luis from Carson Toyota, Nice fella
Old Jul 24, 2008 | 10:22 AM
5sp_jzz30's Avatar
5sp_jzz30
you can also just cut your stock one. fastest way to do it.
Old Jul 24, 2008 | 10:35 AM
Baoser's Avatar
Baoser
Put in washers? thats what I did...
Old Mar 6, 2012 | 03:55 PM
2jzsoarerH's Avatar
2jzsoarerH
Does any1 know the part number for the ls400 brake swap bolt part number from carson toyota......i callled but they was not too sure
Old Jan 27, 2014 | 07:23 AM
eblick99's Avatar
eblick99
searched for ls400 caliper bolts and found here. thanks! doing this conversion on my SC na-t.
Old Jan 29, 2014 | 12:01 AM
lexfreak22's Avatar
lexfreak22
Does anyone know how much you need to cut off or how thick the spacer has to be to work witht he stick sc caliper bolts?
Old Jan 29, 2014 | 06:43 AM
grm405's Avatar
grm405
Yes, I measured both bolts when I swapped my calipers 2 weeks ago. The LS bolt is 1.25" long and the SC bolt is 1.365", so you would have to grind off (don't try to cut as it is too little) about .115", slightly under 1/8". If you use washers you might need 1 if it is a really thick heavy duty one, or 2 normal washers. Apparently only one bolt needs to be shortened, the top if I remember, as the other has enough clearance to use the SC bolt.
Dial or digital calipers are around $10 at Harbor Freight or similar places. They are very handy and a good investment as saying .115" is a lot more helpful than saying "a smidgeon".
Gerry
Old Jan 30, 2014 | 11:25 PM
lexfreak22's Avatar
lexfreak22
Gerry
Thanks for the information. My calipers should be in soon and i cant wait to put them on.
Old Jan 31, 2014 | 08:58 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I grabbed 2 new bolts (1 for each side) and all new spring pins etc.. from the dealer before I did my swap. I mean why not get the right bolts unless you are in a rush, which I wasn't at the time.
1999sc300
May 5, 2017 01:27 PM
Armitage
Suspension and Brakes
Apr 23, 2017 04:30 PM
2jzsoarerH
Mar 7, 2012 12:12 PM
fuel4blood
Aug 20, 2010 07:21 AM
Opaque
Oct 15, 2008 04:12 PM
