Suspension Question
Old Mar 11, 2008 | 09:51 AM
ekrebs's Avatar
ekrebs
Default Suspension Question
I have the Tein SS on my SC and i made sure that i set them up in the front at the same thread count( about 5 ), but it seems to sit lower on the drivers side then the passenger side in the front !! Any ideas as to why this might be happening??
Thanks
Old Mar 11, 2008 | 02:20 PM
TheMole's Avatar
TheMole
Is it noticeable lower or just a little? Some say that Lexus has the driver's side set a little lower from the factory.
You can also check to see if you put the endlinks back the same way when you installed the coilovers.
Did you get an alignment after you switched out your arms?
Old Mar 11, 2008 | 02:39 PM
ekrebs's Avatar
ekrebs
Ya i got the alighnment, i noticed this before the arms just fig id recheck during the arm swap!
Its maybe 3mm higher on the passenger side, and i have not put the end links on cuz im waiting on the TT front sways!
You really think the sway bar not active will cause this???
Thanks again sc300max for takin the time to provide input again!!!
Old Mar 11, 2008 | 02:46 PM
TheMole's Avatar
TheMole
No problem.
3mm is about 1/10 of an inch so you have a pretty good eye. I don't think I would be able to notice.
See what happens after you install the sways/endlinks. It may be set like that from the factory. If not you can always adjust the coilovers if it bothers you that much.
Checkout these links:
https://www.clublexus.com/forums/sho...d.php?t=235324
https://www.clublexus.com/forums/sho...d.php?t=177329
Sash1mi
Suspension and Brakes
Mar 14, 2010 12:58 AM
soulific
Feb 14, 2010 08:40 AM
gs4bkny
Sep 17, 2009 07:18 PM
SloGS400
Oct 6, 2007 08:30 PM
