coolant temp (this normal?) pic
Old Mar 10, 2008 | 06:01 AM
snidehocke's Avatar
snidehocke
Default coolant temp (this normal?) pic
lately my coolant temp doesn't go higher than than shown in the picture. I added some coolant yesterday (was a little low).
this pic is on my way to work today. it's 45 minutes into the highway drive w/ it being 60 degrees outside...
it used to go one line higher
Old Mar 10, 2008 | 06:18 AM
amorphous's Avatar
amorphous
This is more than likely the thermostat that is malfunctioning. Try to get it replaced i think that the sc has two but i'm not sure.
Old Mar 10, 2008 | 06:21 AM
Knightridr's Avatar
Knightridr
I had the same problem. It was the thermostate. I only found one. Its real easy
Old Mar 10, 2008 | 01:27 PM
jgdynamics's Avatar
jgdynamics
really easy to change, my car would take a while to warm up also so i changed the t-stat and problem solved. make sure u get the new gasket with it also.
Old Mar 10, 2008 | 07:01 PM
Steelwheel's Avatar
Steelwheel
Would also recommend getting one from Toyota/Lexus dealer rather than the local autoparts store. From what I've seen, they appear to be made better. Good Luck.
Old Mar 11, 2008 | 06:23 AM
lexdud's Avatar
lexdud
I would LOVE to have my temp needle that low ... even if it means the thermostat isn't functioning properly. That should be a cheap and easy fix. Just remember to clean the block and use some sealnat when applying the new gasket.
My nominal temperature is just above the second bar from the bottom.
Good luck ...
peterls
24
Sep 29, 2019 02:41 PM
dkls400
20
May 6, 2013 05:41 AM
adreano17
Jan 25, 2013 06:53 AM
mjes300
Aug 5, 2009 05:40 PM
persian451
Aug 13, 2003 09:37 AM
